Old 04-05-2009, 08:19 AM   #1
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
Planning first oil change @ 500 or 1000mi
As I've done with most of my new cars, I plan on changing the factory oil at 500 or 1000 miles. I feel that getting that break-in oil out asap is a good thing, and I find the motor gets quieter and feels nicer after that first change.
Can anyone give me a good reason not to change the oil that early? I'm assuming Toyota does not use some special break-in oil that I need to keep in there for the first 5000 miles.
I plan on using Toyota oil for the first change (I know, I know, price gouging), then switching to another brand after.
Thanks all!
Old 04-05-2009, 08:21 AM   #2
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
I believe it DOES have break-in oil with detergents to wear correctly during the first oil-change period.
there have been threads on this already
Old 04-05-2009, 08:24 AM   #3
schleppy
I love momentum.
schleppy's Avatar
Reading some of the existing threads, this seems to be a point of contention for a lot of people. I don't want to open a can of worms.
I guess my only real question is whether or not the oil in the car from the factory is special or not. If it is, I'll keep it, if it's not, I'm going to change it out. Cheap insurance in my mind.
Old 04-05-2009, 09:51 AM   #4
MadMax
MadMax's Avatar
Read and follow your owner's manual...
Old 04-05-2009, 11:09 AM   #5
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Change the oil after 1000 miles. It shouldn't make any difference.
Old 04-05-2009, 01:19 PM   #6
YarisSedan
Drives: 08 Yaris Sedan
I changed my oil after 500 miles. Then installed a magentic drain plug and powerful magnet on my oil filter. And changed it again in another 1000 miles. You wouldnt belive how heavy the oil filter was after 1k miles from all the metal wear particles trapped inside. And the magnet on the oil drain plug as well. If you have ever changed the transmission fluid on a honda that has a magnet on thier drain plug you know what i mean when i say it took several whipes of a rag to get it all off.
I think its a good way to extend the life of your oil pump. As well as cut down on engine wear. Little bit extra money but cheap insurance.
Old 04-14-2009, 08:01 PM   #7
andaconda
andaconda's Avatar
Drives: '09 Yaris Sedan
On any car that I have purchased I have always changed the oil and filter at 500 miles, then again at 1500 miles, again at 3000 miles -- then kept them on 3000 mile intervals. Never changed oil without changing the filter too. I have never had any problem doing it that way over the years.
andaconda is offline   Reply With Quote
Old 04-14-2009, 09:05 PM   #8
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Dude those arabs should send you a plaque for generosity above and beyond the call of duty.Arent you glad you dont have to use Shell Helix oil at $80 a quart.
Old 04-14-2009, 09:49 PM   #9
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Oil preferences and oil changing habits are one of the "holy wars" of every automotive forum. You'll never get a concensus.
I doubt that the factory fill oil is anything special, just bulk oil of the correct spec. I also doubt that there's any benefit to changing it before 5k miles, but do it if it makes you happy.
I DO have an opinion on synthetic oil, however. Every engine needs to break in for optimal performance. If you switch to synthetic oil too soon, you stop or at least greatly hinder the break-in process (yes, synthetic oil is that good). If you're going to use synthetic oil, wait until after 5k miles to switch. Then (holy war point again), aside from the warranty requirement to change the oil at 5k, you can get away with 10k synthetic oil changes if you want.
Old 04-15-2009, 07:46 AM   #10
jambo101
jambo101's Avatar
If the engineers who designed the engine say to change the oil at 6000 miles/10000kms thats good enough for me i'll presume they know more about the engine than i do .
Old 04-15-2009, 08:05 AM   #11
schleppy
I love momentum.
schleppy's Avatar
I'm 100% with you on this one. I will do at least the first three oil changes using dino, then consider switching to synth.
Old 04-15-2009, 08:36 AM   #12
5000miles or 8000km. don't get people wrong here.
Old 04-15-2009, 09:12 AM   #13
andaconda
andaconda's Avatar
I know, I know...
But I've always had good luck doing it this way.
As for oil brands --- each to his own. I think any name brand is ok.
I work in a fleet shop and have used the cheapest oil that is bid out.
We change at 3000 miles and most of our vehicles go 2 and 3 hundred thousand miles without any engine problems. Now that's on the least expensive 5w30 oil that we can find.
Old 04-15-2009, 09:38 AM   #14
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
changed oil at 1000 miles and installed header/crank pulley at same time....
Old 04-15-2009, 12:21 PM   #15
jambo101
jambo101's Avatar
I know, I know...
Double the oil change interval on one or two of your fleet vehicles and see if there is any noticeable difference after 250k.if no difference tell your boss you have a great way of saving the company some money and its also good for the environment.
Old 04-15-2009, 12:43 PM   #16
DerFlosser
DerFlosser's Avatar
Dropped the oil at 1,000 miles and switched to synthetic. Changed again at 3,500. Now I will continue the synthetic regimen every 3,000 miles or 6 months (whichever comes first).
DerFlosser is offline   Reply With Quote
Old 04-15-2009, 01:42 PM   #17
andaconda
andaconda's Avatar
As a matter of fact -- Last year to save money, they changed the interval themselves to 5000 miles between. I disagreed with the policy, but it was not my call. We average about 6000 miles a month on each vehicle. We have had two blown engines, both Buick V6's, both at about 50,000 miles. Warranty covered both of them. One cam failure on a GMC diesel that was not covered. I personally would go back to 3000 changes myself.
Old 04-15-2009, 02:17 PM   #18
evil genius
Drives: 09 Yaris S 3dr
Agree. My dealer had a new car buyer seminar and they stated any deviation from oil change recommendations can void lubricated parts warranty. For me, I'll be hitting 6 months with about 365 miles and I will be taking it in for scheduled maintenance.
evil genius is offline   Reply With Quote
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 09:22 PM
Oil Change Issue. Twistoffate0817 General Yaris / Vitz Discussion 56 05-05-2009 10:27 AM
Oil change time... yay! YarisFan007 DIY / Maintenance / Service 10 09-19-2007 05:40 AM
