Old 02-25-2012, 02:21 PM   #19
The anti-fouler goes on the SECOND O2 sensor, on the midpipe, NEVER on the first air/fuel sensor on the header.
And, if you didn't before, disconnect the battery for 10 minutes to force ECU re-learn. You'll get more out of your new header if you do.
Old 02-27-2012, 09:26 AM   #20
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
Thanks for the tip Garm! Would it work the same if I just unplugged the ECU itself so that my radio doesn't go all stupid and lose its settings, or do I need to disconnect the battery from everything?
pennyracer, I can already tell some improvement, most noticeably on the low end. The torque feels better and the acceleration is smoother. I also have a HK axle-back, NST 10% underdrive pulley, and AFE short ram intake. With the combination of the other 3 mods I had a weird slowness during accel until the car got to about 1500ish RPM, after which it would launch proper. Not sure why that was the case, but with this header it's a much smoother acceleration.
Old 02-27-2012, 09:29 AM   #21
47_MasoN_47
Also I see you mention getting it tuned in other threads. What exactly does this entail?
Old 02-27-2012, 10:24 AM   #22
I would disconnect the battery. Best not to fool with your ECU.
Break a pin = dead car
Tuning involved wiring in a management system and tuning on a dyno with someone who knows what they are doing.
Old 02-27-2012, 10:47 AM   #23
47_MasoN_47
Sounds expensive. Is it worth it?
dc sports, exhaust, header, sensor
DC Sports Header install and evaluation Loren Performance Modifications 217 07-04-2017 06:40 AM
Megan Header Install [pics] Chris07LB Performance Modifications 132 09-29-2010 03:41 PM
Megan Racing header install and review with pics. Herbicidal Performance Modifications 6 09-03-2009 08:40 AM
Pre Hack Revival: Megan Racing Header vs Ebay Header Sabretooth Performance Modifications 15 08-19-2009 05:26 PM
Are We Still Stuck With the 4-1 Headers? Sabretooth Performance Modifications 31 02-20-2009 08:57 PM
