Old 02-24-2012, 10:42 AM   #1
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
WTF DC Header problem
Ok, last night I finally decided to install the DC Header I bought from Garm on black friday. It took about 2 hours just to get the old one off, since Toyota was kind enough to tighten every bolt on my car with the fury of a thousand suns. After getting all that stuff off, the new one went on really quick. Unfortunately, the damn spring bolt on the midpipe flange is running right into the O2 sensor, so there's no way to tighten it down. Thus I have an exhaust leak that sounds like a BBC anal pornstar farting the whole time I go down the road.
I read several threads of people installing these without problems, and the included documentation says to use the existing spring bolts. I don't see how this is even possible though with the O2 sensor sitting right over the damn bolt hole in the flange.
Help?
Old 02-24-2012, 11:02 AM   #2
You have a gasket in there?
and great pictures btw, wish everyone included clear images of the problem.
Old 02-24-2012, 11:17 AM   #3
47_MasoN_47
I'm not real sure, would that have been stuck to the original header or the midpipe? I never saw a gasket when we pulled the old one, unless it's stuck up in the collector of the header and I just thought it was piece of it. Where's the gasket normally at?
Thanks Garm.
BTW it was interesting to try to get pictures from underneath the car while doing weird acrobatics at 1am to get a flashlight and my phone up in there. It took many tries to get clear ones.
Old 02-24-2012, 11:27 AM   #4
The gasket could have stayed stuck to either the header or the downpipe. Check your OEM header to see if it is in there. Based on your pics, it would appear that no gasket is in place. The header/pipe gap is far too narrow.
Old 02-24-2012, 11:29 AM   #5
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
yea, looks like this. Should have swapped it out of the old header
-Derrick-
Old 02-24-2012, 11:46 AM   #6
47_MasoN_47
Fuck. Opened the box in the trunk and yanked on the end of the collector and sure enough, I left the gasket on there.
Think I can get it on the new one without taking the header back off?
Old 02-24-2012, 11:51 AM   #7
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
FYI, I've had to replace my header gasket (with stock header and stock downpipe). Guy at the muffler shop said was common. I might suggest buying a new one just to give you a couple extra years of no worries.
2006 Red Blitzed RS 5-door
Old 02-24-2012, 12:24 PM   #8
I think the exhaust has some play in it, and you can get the gasket in there without removing the header.
I think the gasket will create the gap you need so the bolt fits and the O2 sensor is safe.
More great pics, please.
Old 02-24-2012, 12:34 PM   #9
There is just enough play between the pipe and header to worm the gasket in. Pay attention to the pic posted by ilikerice. It shows the correct orientation of the gasket.
BTW, this is what my gasket looked like after 5 years on the road.
Old 02-24-2012, 12:38 PM   #10
47_MasoN_47
Sweet. I'm checking around to see if anyone here at the office happens to have a floor jac in their trunk. If so I'll just jack it up in the parking lot and install it real quick. If not I guess I'll wait till tomorrow morning.
I'm kicking myself for leaving that out.
Old 02-24-2012, 01:27 PM   #11
Nice!
Old 02-24-2012, 02:17 PM   #12
47_MasoN_47
Holy crap, that thing is rough!
The one I have still looks good. My Yaris is 3 years old with 39.4k miles on it.
Old 02-24-2012, 03:02 PM   #13
47_MasoN_47
Got a jack, crawled up under there and put the gasket in. It's running like a BAWSE now. Thanks for the help fellas!
Old 02-24-2012, 03:08 PM   #14
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Is that with or without the defouler?
Old 02-24-2012, 03:39 PM   #15
47_MasoN_47
I'm just using a stock O2 sensor. DC didn't say anything about needing a defouler.
Old 02-24-2012, 03:47 PM   #16
1.5
Form>Function
1.5's Avatar
o true you might throw a CEL in the future.
Old 02-24-2012, 03:48 PM   #17
47_MasoN_47
Hurt anything or just be annoying? I guess it can be swapped out without taking the whole thing apart at least.
Old 02-25-2012, 12:45 PM   #18
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
hi did you feel a slight gain with the dc header installed ?
pennyracer is offline   Reply With Quote
dc sports, exhaust, header, sensor
DC Sports Header install and evaluation Loren Performance Modifications 217 07-04-2017 06:40 AM
Megan Header Install [pics] Chris07LB Performance Modifications 132 09-29-2010 03:41 PM
Megan Racing header install and review with pics. Herbicidal Performance Modifications 6 09-03-2009 08:40 AM
Pre Hack Revival: Megan Racing Header vs Ebay Header Sabretooth Performance Modifications 15 08-19-2009 05:26 PM
Are We Still Stuck With the 4-1 Headers? Sabretooth Performance Modifications 31 02-20-2009 08:57 PM
