Old 03-13-2012, 05:09 PM   #19
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
CAI not the lights, peru bumper mo baba.
K&N meron dito sa Riyadh or you could source it from the US pareho lang price
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 03-24-2012, 01:10 AM   #20
syntax
syntax's Avatar
@ amaze2, tanggal lang ang headlights ni cutie dito dahil nag MOD sya sa headlights nya. at naka SRI sya, sa CAI, may long tube na papunta sa may ilalim ng headlights at ibaba ang bumper.
sidenote: pwede rin tanggalin ang driverside headlight for better access.
Old 04-09-2012, 06:33 AM   #21
Onads
Onads's Avatar
Drives: Vios/Yaris
Mas maganda ang CAI (Cold air Intake) setup mas malamig ang higop ng hangin kasi usally nasa likod/baba ng bumper ang cone nito malayo sa engine. As what syntax said long tube ang gagamitin. Advantage: Malakas ang hatak. Disadvantage: Prone sa alikabok, buhangin, tilamsik ng tubig. SRI naman usually common setup sa most cars.
Onads is offline   Reply With Quote
Old 04-09-2012, 06:40 AM   #22
Onads
Onads's Avatar
Drives: Vios/Yaris
For me lang I prefer to use the K&N drop in filter. No modification/replacement sa tube ng intake. Para ka pa din naka stock iba lang ang gamit na filter iba na din ang higop ng hangin nya since you're using aftermarket filter. K&N the best. Check the web for reviews about this K&N drop in filter.
Old 04-09-2012, 06:55 AM   #23
syntax
syntax's Avatar
pre naka K&N drop in filter din ako dati, nag switch ako sa SRI dahil para sakin, medyo restrictive pa rin dahil OEM ang airbox, dahil sa pinapasukan ng hangin ay ung nakabaluktot na tube sa tabi ng airbox,
Old 04-11-2012, 03:38 AM   #24
Also note where the power/torque increase will be.
Stock intake box provides good torque in the low end of the rpm range
SRI is more low to mid range pick up and won't make as much gains in the higher end
CAI doesn't have much gains (might actually lose torque) in the lower end and is more useful in the mid to higher end of the rpm band
So it all comes down to where in the rpm band you really drive in.
Old 04-18-2012, 10:10 AM   #25
syntax
syntax's Avatar
+ 1 and your driving style...
Old 05-08-2012, 08:56 AM   #26
BoyMalambing
BoyMalambing's Avatar
Drives: Toyota Echo 2005
Pwede ba ito sa Toyota Echo 2005 1.3 engine...
This is my 1st first car in Saudi Arabia
BoyMalambing is offline   Reply With Quote
Old 05-16-2012, 03:18 AM   #27
syntax
syntax's Avatar
diskarte na lang pre kung saan dadaan ung tube at kung hindi magiging restrictive ang air flow ( straight na tube at walang liko liko)
Old 05-16-2012, 03:45 AM   #28
BoyMalambing
ah ok... so pwede ko siguro tanggalin yung airfilter stock then palitan ko lang ng air filter na ksama ng Air Intake Kit para di na ko magpapacustomize ng Pipe since straight usually ang kasma ng mga ktis.... what you think kabayan Syntax
Old 05-16-2012, 04:10 AM   #29
syntax
syntax's Avatar
post ka naman ng picture ng engine bay mo para makita natin kung saan dadaan ang pipe at san ippwesto ang cone type na air filter, paki picture na rin ung sa may throttle body at maf location
Old 05-16-2012, 04:41 AM   #30
BoyMalambing
Engine Bay pic
Kabayan syntax, eto yung engine bay pic ko
Old 05-16-2012, 09:37 AM   #31
syntax
syntax's Avatar
check natin pre kung ano pwede, katulad din kasi ng layout nyan ang toyota Xa
Old 05-26-2012, 01:48 AM   #32
BoyMalambing
@ Syntax.... nakakita na ko ng Air Filter sa Olayan Car & Accessories.... yung K&N nasa 270SR.... yung SIMOTA 95SR lang... pwede na siguro un... Tanggalin ko na lang yung Air Box tapos gamit ako T-pipe para sa MAF sensor......
Old 05-26-2012, 01:52 AM   #33
syntax
syntax's Avatar
pre make sure na meron din para sa vacuum return line ung tube na iccustomize mo, ung tube na nakakabit sa may air intake
Old 05-26-2012, 02:30 AM   #34
BoyMalambing
plan ko is tanggalin ko lang yung Air box. yung hose from engine same pa rin. yung Air box papalitan ko lang ng air filter ng simota. problem ko ngayon is yung kakabitan ng MAF sensor since naka-built in sa air box yung lagayan ng MAF sensor.
Old 05-26-2012, 03:05 AM   #35
rickyml
rickyml's Avatar
Drives: Yaris 2008
yan yung pinahahanap ko na 95SR na simota eh. available na pala ulit wahhh
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
rickyml is offline   Reply With Quote
Old 05-26-2012, 03:06 AM   #36
syntax
syntax's Avatar
nope... bale ang mahihigop na hangin nun ay ung katabi ng engine which is hot air, not advisable pre' best option dyan ay ung nakakabit sa throttle body. mag fabricate ka ng tube para dun at ilalagay mo sa harap ng battery at likod ng headlights
Cold air intake vs air intake Liu997 Performance Modifications 15 11-05-2009 05:32 PM
