Old 03-08-2012, 03:14 PM   #1
amaze_2
amaze_2's Avatar
Drives: 2008 yaris
cold air intake.
mga kayaris saan tayo pwede mag pa kabit nito ng cold air intake?di ba makaka apekto sa performance ng engine?
amaze_2 is offline   Reply With Quote
Old 03-09-2012, 12:26 AM   #2
VIRAGO
VIRAGO's Avatar
Drives: TOYOTA YARIS Y
@ amaze 2. sir may talyer po tayo ngayn march 9,2012 or kontakin mo n lang ako 0502747943 para maiguide kita kung saan yung talyer
VIRAGO is offline   Reply With Quote
Old 03-10-2012, 12:14 AM   #3
syntax
syntax's Avatar
@ virago nakapunta ba si amaze2 sa talyer? malesh na late ako eh..
@ amaze2 mas gaganda ang performance kapag naka cold air intake ang mga makina natin, lalo mo ito mapapansin kapag naka rekta ka na...
Old 03-10-2012, 02:59 AM   #4
rickyml
rickyml's Avatar
Drives: Yaris 2008
nagpapahanap nga ako kay insan paolo kung available pa ang simota na nagsale sa olaya... kaso wala na raw. sayang naman...
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
rickyml is offline   Reply With Quote
Old 03-10-2012, 03:13 AM   #5
syntax
syntax's Avatar
@ insan oo nga pre wala na ung naka sale na simota sa olayan, kapag may nakita ako na K&N abisuhan kita.. check ko rin kay charliexx kung saan nya nabili ung sa kanyang K&N
Old 03-10-2012, 03:29 AM   #6
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
k&n merong available, kung need ninyo pasabi lang kayo ang size ng rubber grommet niya is 3inches, ang ating stock ay 2.5
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 03-10-2012, 03:41 AM   #7
syntax
syntax's Avatar
pre magkano ang score mo sa K&N?
Old 03-10-2012, 03:51 AM   #8
charlieXX
Corporate Slave
charlieXX's Avatar
Pao 250sar
Pao enge email mo ipadala ko yung dapat ipadala sa iyo sekwet!
Old 03-10-2012, 04:46 AM   #9
syntax
syntax's Avatar
@ charliexx YGPM
Old 03-10-2012, 05:26 AM   #10
charlieXX
Corporate Slave
charlieXX's Avatar
Thanks tol,
Old 03-10-2012, 12:49 PM   #11
amaze_2
amaze_2's Avatar
Drives: 2008 yaris
@virago na ka cold air intake bang yaris mo?K&N may nabasa kasi akong thread dito nagkakaproblema daw sa hatak at sa sensor ng air filter.mayron nabang kayaris na nagpa install nito? pakiupload naman ang pic.salamat.kasi sabi nila makadagdag daw ng horse power mahina kasi ang power ng yaris.87Hp lang malakas pa ang accent.
Old 03-10-2012, 12:49 PM   #12
amaze_2
amaze_2's Avatar
Drives: 2008 yaris
@syntax cold air intake ba ang setup mo ng yaris natin?
Old 03-10-2012, 12:58 PM   #13
amaze_2
amaze_2's Avatar
Drives: 2008 yaris
ok naman ang batak ng yaris ko pero baka mas malakas pag naka cold air intake kasi napapansin ko pag malamig ang panahon mas malakas ang hatak.
Old 03-10-2012, 01:55 PM   #14
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
tol halos lahat ng kayaris both central and eastern region naka CAI na, wala namang problema sa hatak basta tama at sukat ang MAF pipe
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 03-11-2012, 04:22 AM   #15
charlieXX
Corporate Slave
charlieXX's Avatar
@amaze SRI or CAI will add horsepower to boot yes but not that significant that it is like the end all and be all mod you could do.
But it is worth it, as I did to mine see pics to appreciate the K&N, merong Simota, merong Spectre pare pareho lang yan nagkakatalo lang sa branding at pogi points......pero kung pogi na driver so wala ng problema diba.
Old 03-11-2012, 04:23 AM   #16
charlieXX
Corporate Slave
charlieXX's Avatar
Side note: malakas pa ang accent yes, pero I would not get one dahil sa ka-officemate ko roughly a year old may kalampag na pang ilalim, si Cutie ko eh going on 3 years na wala ka pang marinig sa pang-ilalim
Old 03-11-2012, 12:32 PM   #17
amaze_2
amaze_2's Avatar
Drives: 2008 yaris
@charlie XX thanks sa info.para sa MAF mo ginamit mo ba ang original mo.pinutul din ba tulad ng ibang ka yaris natin?saan tayo pwede makabili ng cone filter.?at mga gamit para sa CAI?
Old 03-11-2012, 12:33 PM   #18
amaze_2
amaze_2's Avatar
Drives: 2008 yaris
kailangan bang tanggalin ang ilaw pag ikabit ang CAI?
Cold air intake vs air intake Liu997 Performance Modifications 15 11-05-2009 05:32 PM
