Old 04-23-2012, 02:48 PM   #19
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Originally Posted by DeathBeard View Post
is this kit hard to install? any diy's?
Yes. See my sig...
Old 04-23-2012, 05:06 PM   #20
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Originally Posted by TOLMACH View Post
courtesy of some king YW guys
http://www.yarisworld.com/forums/showthread.php?t=39144
I believe if you do not have 1/2 inch ratchet you can use a different one with required sockets ))
That's correct, whatever size driver you have should work as long as it's the right sized socket.
Old 04-23-2012, 06:52 PM   #21
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
the hard part depends on if you get the bracket that Micro image can supply. the horseshoe clips on the OEM bracket are kind of a pain to get out, but once you get those out it only takes some time. if it was not for those clips it would have taken me less than an hour to install include removal of some parts that will be in the way.
Old 04-23-2012, 09:29 PM   #22
Golddeenoh
Golddeenoh's Avatar
about an hour and a half over all, i spent 45 minutes just trying to get those clip out. they are way easier going back in. if you have a dent puller(slide or slam hammer) that works great if you can get it under the edge and pop it a few times.
Old 04-27-2012, 04:32 PM   #23
Spidermandud
Spidermandud's Avatar
Drives: Black '08 Yaris Hatch S
Originally Posted by EPyarisdriver View Post
Soo I should be getting some serious power from these then huh..
Are you not? I'd think you'd easily be able to outrun anything with all those.
-Will-
Spidermandud is offline   Reply With Quote
Old 04-27-2012, 10:06 PM   #24
Golddeenoh
Golddeenoh's Avatar
now for the fun part, getting to the tranny. :D
Old 04-29-2012, 10:55 AM   #25
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Overall install time- 2 hours .. if I have to do it again would probably take me 30 minutes
To remove the horseshow clips just used big flat screwdriver (20 seconds to remove both)
Congrats! And 20 seconds to remove those clips? Lucky! Mine took a bit longer, as they were really stuck on there.
if anyone can see anything wrong with my installation (pic above), pls let me know
Looks good from here... get to go out and drive it yet?
Old 04-29-2012, 11:49 AM   #26
GREAT picture showing the bracket install and orientation. Thanks for posting it.
Old 05-01-2012, 12:12 PM   #27
Golddeenoh
Golddeenoh's Avatar
I am so glad i put this in, I took my wife's dog to get fixed yesterday and it was nice to able to shift will the dog was laying across my arm.
Old 05-01-2012, 01:49 PM   #28
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
any field tests yet?
Old 05-16-2012, 11:11 AM   #29
ijose 845
ijose 845's Avatar
Drives: 07 Toyota Yaris
i just ordered mine today
does it really make a difference?
Angry Bird Crew #1
ijose 845 is offline   Reply With Quote
Old 05-16-2012, 11:53 AM   #30
^ Yes it does!
Old 05-16-2012, 12:28 PM   #31
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
I purchased the 3" extender and it shifted like a mack truck. I added the short throw shifter and it now shifts like it did at the stock height but at a much more comfortable position.
I am thinking seriously about getting the in-cabin one to go along with it.
it is worth the money, hands down.
Old 05-18-2012, 05:13 PM   #32
ijose 845
ijose 845's Avatar
just got mine in today
i installed it however i coulent fit the washer on the top and the pin it is very tight in their i hope its okay
and would this damage anything or is it safe? because i really like the short shifts
Angry Bird Crew #1
Micro Image Short Shift Kit DIY jpmck03 DIY / Maintenance / Service 17 02-24-2014 07:57 AM
Micro Image lowering springs 1.8" drop markylicious Middle East 144 10-30-2011 01:18 AM
Micro Image Short Shift Kit- prototype review mazilla Performance Modifications 124 09-26-2011 06:04 PM
Micro Image Short Shift Kit cali yaris Micro Image 15 09-07-2011 06:46 PM
Micro Image meet Jan 30, 2010 Brian Photo-Video-Media Gallery 57 02-06-2010 10:27 PM
