Old 11-05-2012, 09:47 PM   #1
YarrrG.Mattee
DIY or Cry!
YarrrG.Mattee's Avatar
Drives: 07 Yaris Sedan, Black Sand
Dam... Might have to make friends with a machine shop...
Artist, Photog, DIY Enthusiast.
-My other Car is pedal powered-
YarrrG.Mattee is offline   Reply With Quote
Old 11-05-2012, 10:25 PM   #2
I like them. But just for the record, this is NOT a very light wheel for 16".
Very light weight wheel at only 19 lbs.
Old 11-16-2015, 08:02 PM   #3
tomm9050
Drives: Yaris 2008 HB
http://i.ebayimg.com/images/g/NwgAAO...bS/s-l1600.jpg
Will these Mini wheels (R100 15x5.5" ET45) fit without any mods? or what mod would be needed? 2007 Yaris HB
Thanks!
tomm9050 is offline   Reply With Quote
Old 11-17-2015, 06:08 AM   #4
Thanks!
Check out the thread below from when I sold my set. Ideally you would like to find a set of hub rings and you definitely need special lugnuts as those particular rims are made to be used with 14mm lug bolts as opposed to 12mm lugnuts:
www.yarisworld.com/forums/showthread.php?t=35571http://
Old 11-17-2015, 04:56 PM   #5
tomm9050
Where might I find the hub rings and lug nuts. What's the purpose for the rings??
How was the performance?
Thanks
Old 11-17-2015, 07:46 PM   #6
Thanks
I bought the lug nuts from Jegs. The hubcentric rings I purchased from another person on here, so I am not sure exactly where you might find them.
As for performance, I really didn't feel any difference from stock steelies, but they definitely looked better.
Old 11-17-2015, 11:23 PM   #7
CoryM
Drives: 2009 5-door, 5-speed
If you're trying to get light mini wheels, try for the ones with the 7 round holes from the R50 mini. They are 12lbs ea. I just got a nice set for $175CAD. Pretty hard to beat that price, and they will work well as winter rims/autoX rims.
Cheers.
Old 11-16-2015, 10:45 PM   #8
CoryM
Not sure about those, but the R50 wheels I just bought are ball-seat (aka radial-seat), so you may need a new set of lugnuts. Other than that, they should be bolt-on wheels.
Old 12-06-2015, 01:18 PM   #9
kimona
kimona's Avatar
Drives: 2014 White VITZ
^^^ Here is a set for sale on craigslist. These ones look pretty good.
http://orangecounty.craigslist.org/pts/5340704371.html
Old 12-06-2015, 07:18 PM   #10
CoryM
Those are the ones I have, except in stock silver. They cut 16lbs of rotating mass which is noticeable. Again, those are a ball-seat nut, so you will need new lug nuts.
Cheers.
FS: Mini Cooper 5 Spoke Wheels with Tires, Hubcentric Rings and Lug Nuts CTScott Items for Sale by private party 14 08-17-2012 11:18 PM
Mini cooper wheels?! T Pexx Wheels, Tires and Suspension Forum sponsored by The Tire Rack 24 04-05-2012 08:55 PM
Mini Cooper Wheels on my Yaris Bmcguigan1 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 04-01-2012 02:04 PM
