#1 |
![]() Drives: 2007 Yaris Hatchback Join Date: Jan 2011
![]() ![]() ![]() ![]() Drives: 2009 Yaris--3dr MT Join Date: Jan 2011
I've been coasting a lot in neutral lately, and just filled up today. It was the second best fe reading I've received to date on a tank of gas. I think why? is onto something, in that it depends on the situation. Sometimes it's best to go with DFCO, but that's not always possible and in those instances neutral fits the bill just fine. I'll keep experimenting.....
#3 |
I've noticed that the engine breaking in the yaris is actually a lot more noticeable than in my cavalier. neutral coasting in my cavalier actually yielded me worse mileage than leaving it in gear.
also, pulse and glide is a proven technique. many guys on gassavers have done it (and still do). there are also guys that EOC (engine off coast) which is the most fuel efficient way but questionable when it comes to transmission wear (that is yet another argument to be had). many guys on gassavers are getting 30+% more than the EPA numbers for their cars and some of the real crazies have exceeded that by leaps and bounds. |
#4 |
![]() ![]() ![]() ![]() Drives: 06 Yaris HB CE Join Date: Aug 2009
is not bad but don't put back to drive while car is moving
#5 |
Only Happy When it Rains
yes because shifting is such a horrible thing to do... Oh wait, that is what the car is designed to do.
Colin Chapman disciple |
#6 |
![]() ![]() Drives: Toyota Yaris LE HB 2008 Join Date: Apr 2012
I only put it from Drive to Neutral when I see that I will need to stop at a red light.
I instantly see the RPMs going from 2200-2300 to 800... Also easier to brake! Correct me if I'm wrong to do that way |
#7 |
![]() ![]() ![]() Drives: 2010 Prius, 2007 Yaris Sedan Join Date: Oct 2009
if you need to stop, or slow down...leave it in drive and take your foot off the gas pedal.
#8 |
![]() ![]() Drives: none Join Date: Feb 2012
I've always thought neutral uses more gas.
#9 |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
I feel safer coasting with the car in gear.
![]() And coasting in gear takes advantage of the deceleration fuel cut off feature where no fuel is being metered to the engine while coasting in gear as long as the engine rpms remain above idle. Whereas when idling in neutral, fuel is being fed to the engine. |
#10 |
Is it hard on the tranny if I put from Neutral to Drive while moving like 20mph ?
#11 |
^ That is correct. Because of DFCO, you'll get better mileage leaving it in gear.
#12 | |
no, it is designed to do that. You have to go through neutral every time you shift.
#13 |
![]() Drives: 07 Yaris 3dr, 09 Yaris 4dr Join Date: Sep 2011
Ok- I see alot of chitter chatter here and a lack of basic automotive technology. Every carmaker that I have ever encountered has placed restrictions on towing an automatic car with the drive wheels spinning. The reason is that auto trans have an oil pump inside that force oils certain bearings. When the auto trans is in neutral, the pump is inop, so no oil to those bearings. If u put ur auto trans in neutral and coast, some bearings are not getting the oil that they should. Now, will short, no oil to certain bearings, coasts cause damage? I don't know and we don't try to findout with my auto trans Yaris. As for a manual trans, the gears spin when the front wheels move and the parts are splash lubricated. Hence, you don't find restrictions for towing manual trans cars with the drive wheels spinning and the trans in neutral. So, I do coast my manual trans Yaris in neutral. Ergo, I cannot believe it good practice to coast an auto trans Yaris in neutral.
#14 | |
Not to mention towing is very different from coasting. Towing assumes the vehicle will never be on at all. Coasting does have the vehicle on and everything running, and if the transmission requires said oils, why would the car not add them just for being into neutral? That would make no sense to me. And while most hyper milers have manual cars, not all of them do. I have not seen any of them blow a transmission from coasting.
#15 |
![]() ![]() ![]() ![]() Drives: 2013 Yaris Join Date: Oct 2011
i had to edit this. couldn't resist.
#16 |
play every day
That's hilarious!
#17 |
Okay, that does it. No more coasting in neutral for me. The extra 2mpg I get isn't worth possibly screwing up my transmission.....
#18 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
Actually, you never stated which transmission you had. Everyone else debated and compared the pros and cons of manual/Auto.
| Q: when shifting into neutral... clutch? | yarisugi | General Yaris / Vitz Discussion | 31 | 04-19-2012 10:51 PM |
| 8.9 Earthquake off the coast of JDM land ..ie Tsunami! | rningonfumes | Off-topic / Other Cars / Everything else Discussions | 28 | 03-25-2011 09:59 PM |
| Coasting in neutral | bankrobber | Fuel Economy Forum | 9 | 03-11-2010 03:55 PM |
| So Close!!!! | aclark246 | Fuel Economy Forum | 13 | 06-07-2009 10:02 AM |
| The Official Having A Bad Day Thread. | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 7 | 11-15-2008 08:38 AM |
