#19 |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
I'll be happy to let you know how this little experiment goes. Many 4 cylinder stock exhaust manifolds employ the tri-y design for more bottom end so it's a tried and true principle. Here's a longer header that illustrates the principle more clearly...
![]() ...and a brief explanation: "Tri-Y's consist of a four-into-two-into-one design, with four primary pipes paired into two slightly larger secondary pipes before reaching a single collector. One advantage of this design is that the increasing pipe diameter broadens the torque curve, providing higher torque throughout the low- and mid-rpm range than a similar four-into-one style header. Headers work especially well for RV's and trucks in which lots of low-rpm torque is important. The principle behind tri-Y design is that the most effective port separation occurs by pairing the cylinders that are firing farthest apart, in other words 180 distributor degrees (or a complete crankshaft revolution) apart." I understand that just installing a header won't make a huge difference, I've always been interested in exhaust designs so it's fun to tinker around with them. And as far as I know, Weapon R is the only manufacturer who makes a tri y for Yaris'. |
#20 |
play every day
Oh oh... looks like I'm already in trouble.
The 2012 header doesn't look anything like the earlier models... ![]() Man, I sure hope the header is at least pointing in the right direction.
#21 |
![]() Drives: 2007 Toyota Yaris Join Date: Mar 2012
I hope you can fit it in there. I eagerly await your review
#22 |
play every day
I'm really counting on the head pipe being the same as all the others...
...because it would mean that even though the 2012 header is of a totally different construction, the relationship of the engine exhaust ports to the head pipe remain the same as the prior years. From what I can tell so far, it's going to be a really tight fit, and jolly good fun trying to get all the bolts back in! |
#23 |
![]() Drives: 2009 toyota yaris sedan Join Date: Sep 2011
TOOTER, still waiting on FE or MPG results on the header.
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
| Enkei's and Dunlops + Medalion Touring Exhaust | 2manywheels | Items for Sale by private party | 40 | 04-04-2011 05:01 PM |
| ))) new TS exhaust question ((( | aucorium | Performance Modifications | 4 | 03-29-2010 01:21 AM |
| does BACK-PRESSURE increase MPG vs straight thru... | marcus | Fuel Economy Forum | 25 | 05-03-2009 09:23 PM |
