#19 |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
Lighten up, W...
(oooh... a pun )Nitrogen being "lighter than air" just struck me as funny because at 78%, most of air is nitrogen. |
#20 |
![]() ![]() Drives: 2007 Yaris LB Join Date: Mar 2011
Pure nitrogen is good for tires because there is no moisture in it and it does not migrate through the tire and bead as O tends to do.
The big caveat is cost. $20-$30 per tire. Think I will stay with free atmospheric for now.
2007 LB W/Cold Wx Package |
#21 |
play every day
That's pricey. I'm with you, I'll stick with free mostly nitrogen, too.
#22 |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Feb 2010
The advantages of nitrogen are, its dry, no rust to wheels or sensors or permeation into the tires. But considering most wheels outlast the car, I don't think that's a big deal. The main advantage is its consistent. Air expands when it gets hot so if you set your tires to 40 and drive a long trip, they may end up at 44 psi. Nitrogen does not do that. you set them at 40 and it stays at 40.
#23 |
![]() ![]() ![]() ![]() Drives: 2020 Corolla Join Date: Apr 2012
I just got new tires on my Yaris .. and I am interested to see how my mileage changes. I am a little scared that my mileage will decrease now that I have new tires on my car. I got Hankook Optimo 4S "All Weather" tires now (only available in Canada I understand). I am running them at about 34 psi ... which I think is normal.
It will be interesting to see if my mileage has changed ... I will know in less than a week probably. BTW .. I opted not to go with Nitrogen as I think that normal air will do me just fine. |
#24 |
![]() ![]() ![]() ![]() Drives: Yaris 5 door liftback Join Date: Jan 2009
#25 |
So far I have no issues with my new Hankook tires. They seem to be just fine .. they are quiet and seem to work well in most conditions. I have yet to try them in snow .. but from what I have seen on YouTube, they should perform well. I have actually also gained 2 MPG since changing tires, so overall I am quite happy.
#26 |
Gray Metalic
Drives: 2012 Toyota Yaris SE Join Date: Jul 2012
From what I've read on it, nitrogen is a dry gas and thus no moisture will be present inside the tire. Also pressure variances due to temperatures are pretty much non existent compared to air. Nitrogen molecules are larger than air so tires stay inflated longer meaning less top offs. Downside is its expensive to replace air with nitrogen.
#27 | |
Gray Metalic
#28 |
![]() ![]() ![]() Drives: 2008 5 sp. LB Join Date: Oct 2010
That seems to be the general consensus here. I run the max psi listed on the tires I have, 44. I also drive a Dodge 1 ton (85 psi) and a 40,000 lb boom truck (110 psi) and just got a winter driver, a 2000 Toyota Rav 4 AWD (40 psi) all the max listed on the tires. I too notice a marked ease of movement, by hand, one finger almost!
#29 |
![]() ![]() ![]() Drives: 2012 Grey Toyota Yaris SE Join Date: Dec 2011
i'm going on a road trip from chicago to orlando so 32 in the front and 29 in the rear for cold tire pressures is good?
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
| NITROGEN GAS TIRE FILL: WORTH IT? | EjDaPogi | Middle East | 15 | 03-20-2011 02:06 AM |
| recurring loss of tire pressure | toad | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 12-10-2009 04:54 PM |
| Tire Pressure and Gas Economy | KittenRD | General Yaris / Vitz Discussion | 11 | 01-25-2007 10:54 PM |
| The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 07:09 PM |
