Old 07-28-2013, 07:55 PM   #19
alohaoba
Drives: Fourtoyotas
You two are totally awesome. Thanks to this thread and your knowledge, I was able to buy the right pressure sensor on EBay for $27 and my future son-in-law installed it on my daughter's Yaris and fixed the air (necessary for this summer's heat in the west where they live). Dealer wanted $1000 to fix the AC.
alohaoba is offline   Reply With Quote
Old 08-27-2013, 12:03 PM   #20
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
update on mine... went to a/c service was told its empty, refilled it with dye and now awaiting.. its been 2 weeks i still got ac and i cant find a leak..dunno what happen previously? but will see..time will tell.
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!!
"Horsepower is how fast you hit the object. Torque is how far you move that object.."
Old 08-27-2013, 01:34 PM   #21
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
Maybe the lost refrigerant went away through the compressor's bushings?
It's virtually impossible to make them totally leakproof if they have to rotate...
Old 07-02-2014, 01:57 PM   #22
Veganman
Drives: 2007 Yaris
AC Pressure Switch for Yaris
Our Yaris needed a new pressure switch and our Firestone dealer said no one sells just the switch. The only way to get the switch was to purchase the hose and switch assembly from Toyota for $275. Ugh. I spent hours on line researching this and finally discovered a company in the good old USA that can provide a brand new Denso replacement switch for $39. Check out www.sourceoneautoparts.com in Michigan. They have a replacement switch for the Yaris, and it is part number 88719-33020.
Veganman is offline   Reply With Quote
Old 07-03-2014, 09:30 AM   #23
marcus
toyota
marcus's Avatar
Had this issue last year had it filled by a shop in august 2013 up until now it's still working... Can is not strong enough to fill it if it's completely empty due to switch not turning it on.. But this may just be on my situation...
Old 07-08-2014, 01:09 PM   #24
Veganman
Drives: 2007 Yaris
Here's where we found a switch in the good old USA. Our Yaris needed a new pressure switch and our Firestone dealer said no one sells just the switch. The only way to get the switch was to purchase the hose and switch assembly from Toyota for $275. Ugh. I spent hours on line researching this and finally discovered a company in the good old USA that can provide a brand new Denso replacement switch for $39. Check out www.sourceoneautoparts.com in Michigan. They have a replacement switch for the Yaris, and it is part number 88719-33020.:smile
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
Removal of the Factory Integrated Source sqcomp In Car Entertainment + Electronics (audio / video / alarm) 7 08-24-2010 12:44 AM
Anybody know of a good oem parts source???? KrystyonWayne Cosmetic Modifications (Exterior/Interior) 4 11-02-2008 05:00 PM
