Old 07-15-2012, 12:08 AM   #19
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
it is just huge, ok :P
Old 07-15-2012, 01:51 AM   #20
Probably my fault, I thought it was -6AN, but I didn't measure it. Should have waited for pimp to post first.
-8AN
Old 07-15-2012, 11:46 AM   #21
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
I bought some -8 to -6 male fitting to go in the ends of the rail. -6an is enough flow for 800hp. I think that should cover it.
Old 07-15-2012, 12:09 PM   #22
pimp my yaris
C'est la vie
Got almost all my fittings together. I just need to get to work. I been feeling a little lazy lately.
Old 07-15-2012, 07:54 PM   #23
Looking good Aras/xbgod, would be nice to see one post without your usual sarcasm though.
I'll check the fittings tomorrow morning.
Pimp has one in hand though, and if a -8 fits his, they are all made the same.
Old 07-15-2012, 07:58 PM   #24
XFACOR
Drives: 1nz-fe
You know it! go big or go home at this point.
But please let your customers know it is 3/4 boss fitttings. You don't need any problems from a faulty install.
Last edited by tk-421; 07-16-2012 at 05:13 PM. Reason: no need for the extra comments...
XFACOR is offline   Reply With Quote
Old 07-16-2012, 01:11 PM   #25
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
So both end of fuel rail are -8an....but like pimp said....you put an adaptee -8 to -6 on each end...and them run -6an hose with appropriate hose ends ...
Am i right ?
Garm can you get the adapter from the hard stock line to -6an fittings ?
Interior:ALL red, black roof
Old 07-16-2012, 02:43 PM   #26
I can provide you with all the fittings based on whatever set up you want.
Old 07-16-2012, 03:02 PM   #27
packetrace
packetrace's Avatar
I can have good prixe on hoses and fittings here in quebec...if you dont mind :)
Fuel rail will come from you of course :)
Old 07-16-2012, 06:06 PM   #28
packetrace
packetrace's Avatar
Have a list of everything needed ?
How much lenght is the hose ?
What is this fuel regulator ? it looks good
Old 07-16-2012, 08:40 PM   #29
pimp my yaris
C'est la vie
Am i right ?
Yes you are 100% correct. I am going to run -6 fuel as a feed line and return line. You can also run a -6 feed line and use the stock fuel line for the return, like Garm. The regulator in the picture is a Areomotive. I dont know how much it cost. I got it used from a friend. This is what I got so far.
http://www.ebay.com/itm/Turbosmart-l...05%26rk%3D1%26
http://www.ebay.com/itm/170856323241...84.m1439.l2649
http://www.ebay.com/itm/180839939544...84.m1439.l2649
http://www.ebay.com/itm/230400476291...84.m1439.l2649
http://www.ebay.com/itm/180864287470...84.m1439.l2649
http://www.ebay.com/itm/310232698361...84.m1439.l2649
http://www.ebay.com/itm/180846322388...84.m1439.l2649
http://www.ebay.com/itm/260896688867...84.m1439.l2649
The bulkhead fitting will go in the top of the pump. I may also buy a -6 inline fuel filter.
Old 07-16-2012, 09:16 PM   #30
packetrace
packetrace's Avatar
Thank you pimp for all the information!! Which are very usefuel!!!
I could have waited for the fuel rail....but I was curious I like to know what to be waiting for....and you are right...these fittings are probably the same as the one they sell double price on summit racing or something :P
Old 07-17-2012, 07:24 AM   #31
pimp my yaris
C'est la vie
-an thread size conversion chart
http://www.gre6.com/ansize
Old 07-19-2012, 07:44 PM   #32
Golddeenoh
Golddeenoh's Avatar
it is cool what you are doing to your xB but I would prefer to see what you can do to a Yaris. 1 toasters don't seem very aerodynamic, where the Yaris is more aerodynamic than an xB (granted still not the most aerodynamic choice). 2 most people on here have a Yaris and would like to see your skills at working in the smaller engine compartment. just some input for ya "XFACOR".
Old 07-19-2012, 10:19 PM   #33
I'm pretty sure we only took off the drivers side ear. On the passenger side, a 90-degree fitting cleared.
Old 07-19-2012, 10:38 PM   #34
Golddeenoh
Golddeenoh's Avatar
maybe you did it wrong :P
Old 07-19-2012, 10:48 PM   #35
Old 07-20-2012, 10:24 AM   #36
Golddeenoh
Golddeenoh's Avatar
couldn't you notch the ear instead of removing it or would that still cause -8 clearance?
fuel rail staypuft Performance Modifications 3 11-21-2008 09:43 AM
