Old 07-28-2012, 06:36 PM   #19
fase4
Drives: Yaris TS 05
I'm seeing those piston on that 1nz-fe and I'm drooling. I want to see a dyno sheet
fase4 is offline   Reply With Quote
Old 07-29-2012, 06:20 PM   #20
Nanoss22
Drives: Yaris sedan 10 std...
Stock piston 195 to 205 compression prius 245 to 260 compress
Nanoss22 is offline   Reply With Quote
Old 07-29-2012, 08:14 PM   #21
That's a huge jump
Old 07-29-2012, 09:38 PM   #22
Viperoni
Drives: 2005 Toyota Echo
That is pretty high too... pumped to see the dyno results!!
2006 Saturn Ion Redline
Old 07-30-2012, 10:54 AM   #23
fast2882
Drives: Toyota Yaris 2012
what is this mean?
fast2882 is offline   Reply With Quote
Old 07-30-2012, 10:55 AM   #24
fast2882
Stock piston 195 to 205 compression prius 245 to 260 compress ?
Old 07-30-2012, 10:21 PM   #25
Viperoni
Stock engine compression (with 10.5:1 compression ratio) is apparently 195-205psi
With the 1NZ-FXE (with 13:1 compression ratio) engine compression is appanrelty 245-260psi
Old 08-01-2012, 12:04 AM   #26
Nanoss22
Did the compresion test 240 only one 238 nice numbers everithing running great...
Old 08-01-2012, 11:20 PM   #27
fast2882
prius engine compression 245-260Psi, Nanoss22 compression 240, so it means the compression ratio is about 12:1 to 12.5:1? wow, if the car use VP racing fuel, i think the power and torque gain will be great. Can't wait for the dyno result.....
Old 08-01-2012, 11:37 PM   #28
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
I wonder what kind of power just the pistons will make and then if you actually tuned for it (maybe with the aem fic).
Old 08-02-2012, 12:17 AM   #29
fast2882
if he use high octane number for fuel like VP racing, increasing the compression from 10.5 to 12, with proper tuning for the ecu, he should have about 10 to 15 extra HP on crank.
Old 08-02-2012, 01:02 AM   #30
ljming99
Drives: Yaris '06
The rough baseline for compression is approx 5hp for every 0.5 increase, so from 10.5 to 12.
I would also give the same answer 10 ~ 15 hp as well =)
ljming99 is offline   Reply With Quote
Old 08-14-2012, 11:49 PM   #31
Autocross72
Drives: 2009 3rd Polar white
Any Dyno numbers yet?
Autocross72 is offline   Reply With Quote
Old 08-20-2012, 07:31 PM   #32
this thread was doing so well.... then splat
Old 08-20-2012, 08:34 PM   #33
BEEF
BEEF's Avatar
I too was hoping for a big nasty dyno graph. something to coax me into doing something foolish with my money.
Old 08-21-2012, 11:25 AM   #34
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
ehh.. its only been a couple weeks since his last post. Probably either blew his engine and embarassed to talk about it or just simply got busy with something else and doesn't wanna waste time with us =(
patience
-Derrick-
Old 08-21-2012, 12:02 PM   #35
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Or enjoying all of that powaaaa lol ^
Old 08-22-2012, 12:53 AM   #36
Nanoss22
Sorry i was specting to have the numbers to and for the moment i dont have the time to go and do the dynopull the work family and the college got me crazy and yes the engine is running good no problems for the moment the car feel very diferent when i step on it so dont worry i will gave u the numbers and some videos of the dynopull... So be pacient
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 02:58 PM
Save thousands and BIG MPG almost PRIUS jay cobbs New YARIS Purchase Forum 6 08-28-2012 08:38 PM
Like a PRIUS... BUY THE YARIS SEDAN......LOOK AT THIS>>>> jay cobbs General Yaris / Vitz Discussion 8 06-07-2012 01:44 PM
SEDAN LOVE CHILD OF CAMRY& PRIUS jay cobbs Fuel Economy Forum 0 05-23-2012 12:42 PM
Toyota says don't call them Priuses -- call 'em the Prii Kal-El Off-topic / Other Cars / Everything else Discussions 7 02-22-2011 10:30 AM
