Old 08-06-2012, 03:00 PM   #19
seth_man
seth_man's Avatar
Drives: 08 Liftback
been using Mobil 1 0w-40 since day 1, 5000 mile drains
seth_man is offline   Reply With Quote
Old 08-06-2012, 05:03 PM   #20
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
I rock the Royal Purple, changed every 5k miles. this way if i bottom out I know that purple means oil and pink means radiator fluid.
Old 08-06-2012, 11:27 PM   #21
Lux
Lux's Avatar
Drives: NCP91
Amsoil 5W-20 full synthetic + Mobil1 premium synthetic filter.
My intervals are 10'000 km. No perceived difference from genuine Toyota 5W-30 motor oil, so far. Regardless of your oil, you should always be using a high quality filter.
Old 08-16-2012, 07:57 PM   #22
pinball56
Drives: 2010 yaris
Originally Posted by ViosFan View Post
Like the title suggests, what do you guys run? Need to take it for an oil change sometime. I figured Pennzoil Platinum 5w20/30, since I figure Ultra might be an overkill for this engine, or Mobil 1 0/5w20/30. I run it for about 6-7k miles per year with 95% of my trips city and <5 miles. Thanks guys
go to napa and buy eneos 5w30 and the napa gold or platnium oil filter , eneos is made by nippon oil company in japan its the number one oil in japan and it is very good oil i have used it for years, its also used in the high end japanese cars it is 100 percent synthetic i run it in my cars for 7000 miles. red line oil, royal purple ,lucas oil, castrol edge , shell synthetic, and quaker state synthetic oil is ok, but it is hard to find their specs in print, like four ball wear, base stock mixture, boiling point, total base number, and other ingredients. mobil one used to be good oil untill it was bought out by exxon oil, and castrol oil is just a shell company their oil is made by whom ever they get the cheapest oil from, but its your decision , amsoil is the best oil out but its pricey unless you get the 5w30 10000 mile brand they sell but you need to use their oil filter to get the 10000 miles for service intervals
pinball56 is offline   Reply With Quote
Old 08-16-2012, 09:39 PM   #23
Blue Beast
Drives: 2010 Yaris 3 door hatchback
At 30,000 on odometer is it ok to switch to a synthetic or better to stay with same as factory installed? All dealer service so far using standard mobil 5w30 and toyota filters.
MI Crank Pulley
DC Sports Header
TRD Stainless Sport Exhaust & TRD HP Air Filter
TRD Sport Shocks, TRD Lowering Springs, TRD Rear Sway Bar
MOTEGI RACING MR121 RIMS 15 x 7, Kumho Ecsta RSX 205/55/15
TWM Short Shifter, Base & Cable Bushings, Weighted Hybrid Shift Knob
VG Shark Fin Antenna, De-badge factory emblems, TRD Black Chrome Badge
Blue Beast is offline   Reply With Quote
Old 08-16-2012, 10:49 PM   #24
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Canola
oil
Intermittent low oil pressure light. Inspector14 DIY / Maintenance / Service 23 03-29-2010 01:46 PM
Synthetic Oil Questions. Twistoffate0817 General Yaris / Vitz Discussion 19 07-15-2009 08:54 PM
Nippon Oil Filter IllusionX DIY / Maintenance / Service 6 12-07-2008 02:00 AM
