Old 10-22-2012, 02:00 PM   #1
Gogogordy
Drives: Miss my Yaris, love my Jeep jk
^ The coil springs are for up and down movemente. We are talking about the horizontal "spring" that we call a sway bar/torsion bar. Different movement. It doesn't come with the car, but the torsion/sway bar is what we are talking about. When the car goes into a corner, the bar resists being twisted, just like your spring example. This transfers weight.
The front bar on the Yaris IS a sway bar - independent suspension up front.
Agreed. I was clarifying Sirius' mis-statement re the Yaris' suspension type.
Originally Posted by Sirius-XM
The Yaris has a torsion beam suspension so the sway bar isn't really a sway bar in the conventional sense but is instead a reinforcing spring for the torsion beam. It attaches to trailing arm part of torsion Beam. If this is the TRD Sway Bar for the Yaris (PTR11-52071), the installation instructions over at TRD Sparks where I got mine.
A sway bar is indeed a torsion spring, but the rear suspension on the Yaris isn't a torsion bar set-up, as Sirius-XM says it is. It isn't.
The sway bar isnt "a reinforcing spring spring for the torsion beam", as he states. It's a torsion spring to be installed (in the case of the Yaris) on a coil-sprung solid type rear axle. Same net effect, but not acting on a torsion bar type of axle.
I'm the Prez at my house...in fact I cruise around in YarForce One!
When I'm not driving my Yaris, I'm doing this:
http://gogogordy1.wix.com/scooter-aficionado
Gogogordy is offline   Reply With Quote
Old 10-22-2012, 02:03 PM   #2
Gogogordy
The sway bar isnt "a reinforcing spring spring for the torsion beam", as he states. It's a torsion spring to be installed (in the case of the Yaris) on a coil-sprung solid type rear axle. Same net effect, to minimize roll but not acting on a torsion bar type of axle in this case.
http://en.wikipedia.org/wiki/Torsion_bar_suspension
Old 10-22-2012, 02:13 PM   #3
Glad we got that all straightened out!
Old 10-22-2012, 02:58 PM   #4
Gogogordy
We're both quite relieved, I'm sure!
Old 10-22-2012, 06:36 PM   #5
Sirius-XM
Toyota (TM) Shareholder
Sirius-XM's Avatar
Drives: 2007 Jade Yaris Sedan
I said the suspension is a torsion BEAM not Torsion Bar.
http://en.wikipedia.org/wiki/Torsion_beam
It is a torsion beam as opposed to two independent swing arms that can be attached in a variety of manners. Using the Beetle as an example, The Beetle had two independent trailing arms that attached to the body via torsion bars in a tube. The yaris has a single unit suspension with a beam that twists to allow the trailing arms some degree of independence.
Sirius-XM is offline   Reply With Quote
Old 10-22-2012, 08:48 PM   #6
Gogogordy
I stand corrected Sirius.
xA or xD front sway bar fit in to 07 Yaris yariseggvvti Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 10-29-2012 09:47 PM
