View Poll Results: Is it work it?
Yes 2 6.67%
No 28 93.33%
Voters: 30. You may not vote on this poll
Old 01-05-2013, 09:55 PM   #1
sternz
Drives: 08 Blazing Blue LB
(Cheap from ebay) Magnetic Fuel Saver
Has anyone used one of these? If so do they really make any difference at all, or are they just a waste? I was just browsing on ebay and noticed these.
this is part of their description;
1) Powermag: Magnetic Fuel Saver can help engine to burn fuel more efficiently
2) Powermag: Magnetic Fuel Saver let your car run more miles per gallon
3) Powermag: Magnetic Fuel Saver will improve engine performance
4) Powermag: Magnetic Fuel Saver will reduce emissions
5) Powermag: Magnetic Fuel Saver will clean air
Magnetic Fuel Saver gadgets increase combustion efficiency for a cleaner burning engine. This reduces harmful emissions while increasing engine performance.
Benefits of Magnetic Fuel Saver
1) Save fuel, save $$, more MPG (miles per gallon )
2) 50% reduction of carbon monoxide and hydrocarbons
3) Helps pass emission testing/smog check
4) High octane performance with lower octane fuel
5) Improved performance - quicker starts
6) Stops scale build-up and corrosion in engine
7) Reduced wear on O2 sensor and catalytic converter
Any info is welcomed! Thanks in advance.
sternz is offline   Reply With Quote
fuel saver, magnetic
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 327 01-02-2026 11:44 PM
