#1 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '14 GT86, '08 Vitz Join Date: Dec 2006
^ how big are those?
#3 |
![]() ![]() ![]() ![]() ![]() Drives: red bare bone yaris hb 3dr Join Date: May 2009
I believe they're 3" , but the housing is even bigger than the TL's
I found the JDM LS460 bix, and i was going to play around with them, but chickened out :) |
#4 |
#5 |
And if you decide getting a halo, just splice it into the parking light wire or run a dedicated switch for it.
#6 |
The retrofit source won't do the install or retrofit , although they can refer you to some installer. But expect to spend at least $200 and up for their labor.
Those mini projectors are plug and play, just make sure you choose the h4 harness . All you have to do is bake the headlights , paint the reflector to a matte Finnish and you will be super happy with the result . |
#7 | |
#8 | |
I'd probably end up going all in and painting the reflector bowls as well, I dig that blacked look So, below are the options that I have/assume I should go with. Any insight on the choices below would be helpful. Ballasts: Morimoto 3Five (35w) Bulbs: H1 Morimoto [FREE] vs. H1 XB35 [$30] - what is the difference between these bulbs? Halos: Morimoto CCFL Kit $25 vs. Morimoto XB LED {White} [$50] - couldn't find anything on their site about the difference between these. Projectors: LHD (North American Standard) Re-Sealing Glue: Will I be needing this regardless, or only if I go through with painting the reflector bowl? Shrouds: I'm waiting to hear back from them about which of these may be optimal for the 07 Yaris Sedan. Any thoughts? Wiring: Relay H4/9003 Now I'm getting excited/nervous .
#9 | |
#10 |
Yup xb is good bulbs , even though the morimotos is actually similar to the Phillips 85122+. I use 5000K , since Its plain white but still a little yellow on the ground ... It really helps during raining days :) .
As for the halos, xb is a lot brighter than the ccfl ... And it comes in different sizes . Those are Andrew's (trs crew) Honda fit , using those Lexus ls460 bix projectors and xb rings . |
#11 |
^ he's selling that Fit, right?
#12 |
![]() Drives: Yaris Sedan Join Date: Apr 2012
I have the spyder projector headlights for my sedan and I havent had a problem with them. What I want to know is, if i change the stock bulbs for HID, would that be a problem or is it safe?
#13 |
![]() Drives: Yaris S 2007 Join Date: Feb 2013
I just recently purchased the spyder headlights for the Yaris 07 Sedan too and installed HIDs in them last night... it's a b*tch trying to aim them right tho since there isn't much space behind the headlight to reach the L/R adjustment screw...
I would like to do the Morimoro 3-five retrofit but didn't wanna spend that much on it yet plus, I'm scared of doing the retrofit too... maybe in the near future tho... |
| Tags |
| projector headlights |
| Yaris vs MR2 Spyder | regal | Off-topic / Other Cars / Everything else Discussions | 36 | 01-25-2026 12:56 PM |
| CF vinyl roof, Spyder LED tails, whole car repainted | 4x4Dragon | Cosmetic Modifications (Exterior/Interior) | 6 | 05-14-2012 11:39 PM |
| Canadians with Spyder Halo Projector Lights | SeriousBlack | Canada | 13 | 11-29-2011 08:04 AM |
