#19 |
![]() ![]() Drives: 07 Yaris LB, 70 Mach 1, 84 5.0 Join Date: Feb 2007
A little water won't hurt the engine. People run water/meth injection all the time. What would hurt the engine is if the entire filter was submerged in water. That could cause hydro-lock which can cause permanent engine damage.
EDIT: You will have to check your filter more often to make sure it doesn't get too dirty. |
#20 | |
![]() ![]() Drives: Toyota Yaris T SPORT Join Date: Feb 2006
#21 |
Dry filters are the rage now because of marketing. Yes, they do require special cleaning as well.
A correctly cleaned and re-oiled filter will not harm your MAF or engine. K&N's been in business for over 25 years, just to name one oil backed filter company... Getting either type of filter wet will not cause an engine to lock up. Its when the filter gets submerged and the engine is running and sucks up a bunch of water. |
#22 |
Drives: lil red 5-door Join Date: Sep 2006
well, if you wash your car by driving it into a swimming pool with the engine running, then you'll have a problem
![]() As Dragonacc said, a little water getting in the intake should not be a problem, the filter should be able to stop most of it, then the rest would evaporate with the heat. The hydrolocking problem occurs when your intake sucks up water instead of air. Imagine you have a straw in your mouth and you are sucking air. when you put the straw a little bit into the water, but you are still able to suck air, the water will not go up much. But once you submerge the hole completely, then water will rise up. Same thing with an engine, if you get liquid water into your cylinders, then you're in deep deep trouble.
The price of freedom of religion, or of speech, or of the press, is that we must put up with a good deal of rubbish. - Robert Jackson ![]() Bye bye 1NZ... |
#23 | |
Yes, picture a porn star going for the happy finish on a 12" dong... same thing. |
#24 |
how very... visual...
#25 |
Resident Redneck
Drives: 07 Polar White Yaris Sedan 5M Join Date: Jul 2006
108 to the flywheel- we're actually pretty lucky that ninety-something of them make it to the pavement. Drivetrain loss is ususally a bit more on most FWD vehicles. It's even worse on RWD cars.
My other rides: 2003 Honda Civic LX Coupe 5M- S/C K24 w/ LSD coming soon! 1999 Honda Civic EX Coupe 5M w/ B18 powaa 1985 Toyota Celica GTS Coupe 5M- track whip http://www.importlounge.com |
#26 |
Break'em off some.
Drives: 07 Yaris LB, 04 Cobra Join Date: Jan 2007
Yes, on our cars there is very little drivetrain weight to get moving, and electric power steering helps keep losses pretty low.
#27 |
Look mum no stars!!
ooooooooooo that sounds hot.....anymore performance noise to my car and it will wake up the whole damn street....my car is already gettin complaints from the locals.....
then im gonna get it soon....yay for CAI'S!! :)
#28 |
![]() Drives: 07 Yaris S Join Date: Mar 2007
you have mean neighbors :)
| WR Secret Weapon Intake Dyno Tested.. | WRLEO | Performance Modifications | 70 | 05-17-2007 04:00 PM |
| WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! | WRLEO | Sponsors Classifieds Area | 0 | 02-22-2007 11:14 AM |
| Reviews of Weapon*R Intake system.. | WRLEO | Performance Modifications | 6 | 02-20-2007 11:12 PM |
| intake question and suggestions | Adriaan | Performance Modifications | 2 | 01-31-2007 05:54 PM |
| Cold Air Intake vs. Short Ram Intake | nevermorez | Performance Modifications | 1 | 01-24-2007 05:25 PM |
