Old 04-27-2016, 05:23 AM   #19
Gagi
Gagi's Avatar
Drives: Yaris 1.33 vvti 2015
According to this catalogue, part number should be 81080-22040
http://www.toyodiy.com/parts/p_E_201...FSKW_8121.html
Gagi is offline   Reply With Quote
Old 04-28-2016, 02:53 AM   #20
karloslatynos
karloslatynos's Avatar
Drives: 2012 Yaris TR 1.33 VVT-i Man
After typing my VIN on the website from your last post it says footwell light are not applicable(?)
http://www.toyodiy.com/parts/p_E_201...FNKW_8121.html
I don't understand how it works when my car is pre-wired for footwell lights but they are not applicable? This is where the confusion is coming from
I've managed to get footwell lights only after I've noticed them in my friends 2015 Yaris Hybrid so by giving his registration number to the dealer I was able to place an order.
I am not sure Gagi if the glove box light has the same part number as the footwell lights. As you said in the post before, your Yaris (and probably my firends too) is pre-wired/ready only for footwell lights so I think using the part number you provided we can get only a set of footwell lights only.
Taking your word on board I am not going to give up make us 100% sure whether my model has the black connector for glove box light or not.
I'm going to do some work on my car next weekend (http://www.ebay.co.uk/itm/2522411108...%3AMEBIDX%3AIT) so I will also take a good look at it.
karloslatynos is offline   Reply With Quote
Old 04-28-2016, 11:01 AM   #21
Gagi
Gagi's Avatar
All this about dealers makes me crazy. But they are not enthusiastic for sure .
Thing is, if you bought car without footwell lights, they in theory are not applicable (like car bought without cruise control, it works when you install stalk, or it works always, you just need switch to turn it on, but still not applicable). Dealers have catalogs, and if your VIN shows NO, they just won't bother with that. On the other hand, at the production line it would be time consuming to worry about different cablings for hundreds of submodels. This is why you have many unused connectors in car.
So back to the dealer. You need to provide part number from catalogue instead of VIN if you are planning to retrofit something. If they ask why do you need that, simply answer that Toyota needs more of your money. Before I bought footwell LED's, I tested connectors with multimeter, to see how they are going to operate. Only after that I ordered two pieces.
If you look carefully in that page of web catalogue, you will notice that you have two types of LED's. One with part number 81080-0D010 that is valid for models made after March 2014, and one with part number 81080-22040 for vehicles made from 02/2012 until 01/2014.
Both parts are for footwell lights and for glove box. Also image of each LED corresponds to exact fitting position in vehicle in comparison to instrument panel image.
Old 05-09-2016, 06:45 AM   #22
scmoky
Drives: Yaris 2012
I have yaris 2012 1,33Vti and also can't find 3 conneector for glove box :( other two for foot light i find in 20 sec, but third one is not present(I check aribag conn. , usb conn, windscreen con, but nothing) So maybe can I connect two lamps to one foot connector? Foot light connector is white with blue and violet cable, you say that glove box F103 coonector is black and can you tell me color of two cables?
If I have 2012 i must ordred 22040?
scmoky is offline   Reply With Quote
Old 05-09-2016, 12:09 PM   #23
Gagi
Gagi's Avatar
In post #18 of this thread you will find pdf attachment of illumination. Scheme represents all lights that goes on with headlight on. According to that, red wire from junction connector F84/F85 goes to F103. Precisely, from F85 pin 21 red wire should meet white wire in black connector F103.
Maybe you can connect two LED on one connector but then you will have glove box illuminated only when door open, key removed etc.
Normally, you should have it illuminated with headlights on.
Best way, locate connector F85. If there is red wire on pos 21, follow it. It should lead you to F103.
Location of F85 you can find in post #16.
Old 05-20-2016, 06:59 AM   #24
Sharky144
Sharky144's Avatar
Drives: Yaris XP13 D-4D
Hello,
I searched for that glovebox connector and wasn't able to find it.
My D4D Yaris (LHD) has been build in 2012.
My question now, why does the partlist explicitly mention automatic air conditioner?
Unfortunately my Yaris only has a manual AC, could this be the reason that there are only connectors for the foot well lights?
EDIT:
I removed my Touch&Go and think i found F85/F84, seems like there is no 21B connected
Sharky144 is offline   Reply With Quote
LED tail lights installed Cutie Pie #2 Cosmetic Modifications (Exterior/Interior) 10 08-20-2012 11:25 PM
Yarisworld.com DIY Manual v3 vodkalush Downloads for Registered Members 30 01-21-2007 10:54 PM
DIY KEYLESS ENTRY on Power Liftback? TC-LIFTBACK DIY / Maintenance / Service 0 08-23-2006 09:57 AM
