Old 03-08-2013, 03:28 PM   #19
TOLMACH
Drives: soarer
Re lower alternator bolt:
Having read all of the above I was kinda scared to touch it. I did try to unscrew it (a little) yesterday (my sc install is coming next week) just to calm myself down that I can do it :))
What worked in my case was that I used a pretty short 3/8 inch ratchet.. which due to its short length I was able to position very conveniently inside the engine bay (ratchet handle pretty much parralel to the ground) and was able to apply very steady force to unscrew the bolt (just turned the bolt 360 degrees and then tightened back). No wd40 was used.
Old 07-02-2013, 11:56 AM   #20
macz100
Drives: yaris
i'm having the same problem with the lower alternator bolt . put some wd-40 and hope it loosens a bit . hate to break the bolt.
macz100 is offline   Reply With Quote
Old 07-02-2013, 01:34 PM   #21
esse10
Drives: 2009 yaris 2 door
alternator bottom bolt
I just did mine this past weeknd and I used a swivel ratchet like the one in this picture with a six point socket, also put something behind the ratchet head between it and the car frame to keep it from popping off when you apply pressure. It also helps if you apply some Pb blaster as best you can on the bolt threads to loosen up, just don't over spray that stuff is STRONG. Then put anti-sieze on the threads when you put the bolt back on for easy removal next time, guarrentee. good luck.
Old 12-25-2014, 03:22 PM   #22
Kar98
Drives: 2011 Scion tC
Something do to next weekend, I guess :D
Seat belt buzzer is silenced billk General Yaris / Vitz Discussion 48 10-30-2013 09:58 AM
seat belt chime disable? Lewis DIY / Maintenance / Service 19 05-25-2012 04:36 PM
HELP!? HORRIBLE drive home during first REAL Snow in Michigan, paulyd0021 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 12-11-2009 08:07 PM
HELP!? HORRIBLE drive home during first REAL Snow in Michigan paulyd0021 General Yaris / Vitz Discussion 32 12-10-2009 01:23 PM
Best Grease to use on the belt? hasher22 DIY / Maintenance / Service 11 04-23-2007 02:20 AM
