Old 04-23-2014, 11:53 AM   #19
Originally Posted by jcboy View Post
why do you know more than i do about my own car? LOL. yes i don't have those sky blue and black wires on the kick panel. just wondering, isnt the retract supposed to go into a module (that the switch's retract button activates)?
thanks for the quote, i don't have money to burn yet for this upgrade, (although i can afford the wiring, thanks to you) i'll let you know once i've saved up for the mirrors.
For the retract, it is simply a function of the power mirror switch. No additional module is required.
Old 04-24-2014, 12:57 PM   #20
jcboy
Drives: Sedan 07
cool, so it's not like the older honda (jdm) that needed a retract module? i understand the wires just reverse polarity to activate the motor in either direction, but isnt that going to cause battery drain? i mean, although it is wired to IGN On and that the motor stops at the hint of it being fully in or fully out, but does the 12V supply stop too?
Old 04-24-2014, 03:31 PM   #21
The switch module handles the polarity switching and limit switches keep it from drawing current when not in use.
Old 04-25-2014, 02:28 PM   #22
jcboy
Drives: Sedan 07
Got it Scott. Thank you.
I will go ahead and check out our junkyards for the mirrors and the switch, and will be in touch with you re the wiring.
Old 08-26-2014, 08:02 PM   #23
Kar98
Drives: 2011 Scion tC
Exactly. Did you check and verify that you are pre-wired?
Hmmm... not sure? I could take better pictures with an actual camera, if needed.
http://imgur.com/a/EMawE
Old 08-26-2014, 08:17 PM   #24
The connector in the second picture (where I believe I also saw bigfoot and the loch ness monster) looks like the correct one for the power mirror switch. It is a ten pin single row connector with 7 positions occupied with wires. I have one of the switches for sale if you need the switch.
Old 08-26-2014, 08:24 PM   #25
Kar98
I saw. That's what reminded me of this thread and prompted me to take the pics
Just gonna see if there's any meteorite gray power mirrors for sale somewhere... and figure out how to swap them...
Old 08-26-2014, 08:34 PM   #26
You don't need gray ones. Buy a cheapo aftermarket ebay set (they come with unpainted black covers) and pop your covers on. That's what I did with the red one.
Old 08-26-2014, 08:44 PM   #27
Kar98
Dammit man, always making me work and improve my car.
Old 10-05-2014, 06:59 AM   #28
jcboy
Drives: Sedan 07
Finally finished with the wiring and installation of these power folding mirrors. im still to have them painted tomorrow though, as i just retouched on the paint with clear coat.
scott and the entire community, thank you for all your support. i was able to do everything by myself. (even freelance mechanics--our motown "banawe" is full of them--had fun watching me doing everything for 3 straight hours)
it's actually a good thing that i didnt purchase the harness from you as the connector for the units here are different from what the rest of the world gets.
Old 10-05-2014, 01:30 PM   #29
ucsmfu
Drives: yaris le
Is there folding mirror assembly for the 2012 YAris ?
thanks
ucsmfu is offline   Reply With Quote
Old 10-06-2014, 04:20 AM   #30
jcboy
Drives: Sedan 07
thanks
As my response is on the other topic, im not sure. But definitely there is at least one other toyota car that uses the same mirrors, worst case is youll have to transfer it to your side mirror base. The 2008-2012 yaris sedan, 2008-12 corolla, 2007-11 camry, auris, yaris, 2009 scion xd all use the same mirror assembly with different base (attachment to the door).
Old 10-06-2014, 06:47 AM   #31
thanks
Not for the US, but there is for Japanese market Yaris.
Old 10-06-2014, 10:47 PM   #32
ucsmfu
Drives: yaris le
Ic, thanks Scott, what if I just go for the mirror turn signals ?
How's the wiring ?
Will this set work ? thnx
http://www.ebay.ca/itm/110960897430?...84.m1423.l2649
Old 10-06-2014, 11:05 PM   #33
How's the wiring ?
There really isn't enough info in that listing to say if they are OK or not. (They say OEM but have no part number info or anything of that nature). Wiring means running wires through the doors to the under dash junction box and tapping the appropriate wires.
Old 10-07-2014, 01:21 AM   #34
ucsmfu
Drives: yaris le
Thanks
Old 10-08-2014, 04:08 AM   #35
ucsmfu
Drives: yaris le
Hey Scott, I received this from the seller
Wiring diagram
http://i.imgur.com/2NQ50gm.png
Old 10-08-2014, 04:21 AM   #36
nookandcrannycar
Not for the US
kuro-kuro, mga sarisaring katanungan xtremist Middle East 2740 01-27-2020 03:36 AM
Yaris Verso: Reset power window jam protection togo DIY / Maintenance / Service 3 01-10-2013 10:03 AM
DIY adding extra power outlets and usb power outlets on the dash to use phone as GPS julienrl DIY / Maintenance / Service 1 08-31-2009 10:06 AM
