Old 02-27-2013, 04:24 AM   #1
A1phazu1u
A1phazu1u's Avatar
Drives: Black 07 Toyota Yaris Sedan
Power Mirror Wiring
My 07 sedan doesn't have the pre-installed wiring for the power mirrors. I can figure out how to wire it myself, but my question is; does anyone know how much voltage should be running through the switch? Thanks in advance
A1phazu1u is offline   Reply With Quote
Old 02-27-2013, 05:45 AM   #2
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
as elsewhere 12V
I like very much travel
MickZEL is offline   Reply With Quote
Old 02-27-2013, 06:28 AM   #3
Is the wiring missing in the doors or is it missing for the switch?
Old 02-27-2013, 01:08 PM   #4
A1phazu1u
A1phazu1u's Avatar
Both good sir.
Old 02-27-2013, 01:30 PM   #5
Both good sir.
Really? I wonder if that is a sedan thing, as the liftbacks without power mirrors definitely are prewired. I wonder if anyone else with a non-power sedan has tried upgrading the mirrors?
To see the door wire connector you have to pull the door panel:
The switch connector was taped to the harness at the top of the under-dash fuse panel:
If you remove the driver's side kick panel and look at the bottom connector, do you have the black and sky blue wires on the top left of the connector shown here?
Old 02-27-2013, 10:06 PM   #6
nookandcrannycar
Is this the case for all model years re the USDM 2nd generation liftbacks?
Old 02-27-2013, 10:10 PM   #7
As far as I know - Yes. I know for sure that 08 and 09 liftbacks without power are prewired, but I haven't seen for sure with 07. If your 07 doesn't have power, check for the switch connector, as that one only requires popping the change cup.
MicZel has an 07 Sedan, that was a USDM Yaris that eventually made its way to Russia. His is pre-wired, as I am in the process of sending him a care package to convert his mirrors to power.
Old 02-27-2013, 10:22 PM   #8
The next time I remove my door panel, I'll see if mine is pre-wired as my car came with nothing, no power anything, no ABS, etc. I'll try to look tomorrow at the interior fuse box to see if I have those wires.
Old 02-27-2013, 11:37 PM   #9
A1phazu1u
A1phazu1u's Avatar
@CTScott
I have no such wiring :(
Old 02-28-2013, 06:10 AM   #10
@CTScott
Interesting. If you still want to use the power mirrors, I have the harness from the switch to the mirrors available. You would then just need to run the three wires from the kick panel into the doors.
Old 02-28-2013, 01:29 PM   #11
Kar98
Drives: 2011 Scion tC
Hmmmm... This is the single one issue that irks me the most about mine, that there aren't even manual remote adjusters for the mirrors. If you're saying they're pre-wired... I'm gonna go and check :)
Old 02-28-2013, 01:48 PM   #12
Kar98
And what, good sir, would this care package contain, he asked, wondering how complicated it would be to convert non adjustable mirrors to power mirrors.
Old 02-28-2013, 01:55 PM   #13
The package contained all kinds of goodies! For the power mirror conversion, literally all that is required (provided that you car is pre-wired) is the remote mirror switch ($50 to $100 depending on new or used) and about $40 each for good quality, new, aftermarket mirrors.
Old 02-28-2013, 08:30 PM   #14
Kar98
So, like these?
http://www.ebay.com/itm/Outside-Side...b0e26b&vxp=mtr
Image for future reference:
http://i.imgur.com/0bNTJqh.jpg
Old 02-28-2013, 08:46 PM   #15
Exactly. Did you check and verify that you are pre-wired?
Old 04-22-2014, 03:37 PM   #16
jcboy
Drives: Sedan 07
hi scott, to put the power mirrors we have here in manila is in my pipeline. but the ones we have here are power retract with turn signal indicators. does the wiring that you're selling have any difference? how much are you giving it away for anyway?
also, i havent checked the skyblue and black wires that you mentioned, but i don't have the big connector hidden anywhere near the junction box (behind the removable sunglass holder (?))
Old 04-22-2014, 10:28 PM   #17
If you don't have the connector for the power mirrors, then it makes sense that the sky blue and black wires are missing as well. With the harness that I have you would need to add two additional pins to the connector for the folding.
For the turn signals, you would have to wire them directly to the wiring that feeds the front and rear turn signals. I could do $30 + shipping for the harness, including the two extra pins.
Old 04-23-2014, 11:50 AM   #18
jcboy
Drives: Sedan 07
why do you know more than i do about my own car? LOL. yes i don't have those sky blue and black wires on the kick panel. just wondering, isnt the retract supposed to go into a module (that the switch's retract button activates)?
thanks for the quote, i don't have money to burn yet for this upgrade, (although i can afford the wiring, thanks to you) i'll let you know once i've saved up for the mirrors.
kuro-kuro, mga sarisaring katanungan xtremist Middle East 2740 01-27-2020 03:36 AM
Yaris Verso: Reset power window jam protection togo DIY / Maintenance / Service 3 01-10-2013 10:03 AM
DIY adding extra power outlets and usb power outlets on the dash to use phone as GPS julienrl DIY / Maintenance / Service 1 08-31-2009 10:06 AM
