Old 04-08-2013, 02:07 PM   #19
Here is one other possibility for those seals. The kit of seals in the bottom part of this image is 04331-52520 (Gasket kit, transaxle overhaul, MTM)
Old 04-08-2013, 02:40 PM   #20
kc0rpm
Drives: 08 yaris sedan
Not quite sure what the number is on the part the dealer just ordered but I will know tomorrow when I pick it up.
kc0rpm is offline   Reply With Quote
Old 04-08-2013, 07:28 PM   #21
kc0rpm
Now I just have to figure out how to drive that seal in with out damaging it. The lip sticking out of it makes it impossible with my standard seal drivers.
Old 04-08-2013, 08:07 PM   #22
Toyota makes a SST (09309-37010) for installing them. I machined a chunk of Oak to insert mine.
Old 04-08-2013, 08:10 PM   #23
kc0rpm
Yeah, I just chucked my largest seal driver up on the lathe and cut down the center to clear the flange
Old 04-09-2013, 10:20 AM   #24
kc0rpm
The correct part number for the left axle seal is 90311-34044
Old 04-09-2013, 11:49 AM   #25
That's interesting. That part number shows in the EPC as only being for the Scion xB.
Old 04-09-2013, 11:58 AM   #26
kc0rpm
Hmm... Well we found it on the epc. Took a lot of digging though and it is most certainly the right part. It matches up exactly with what I pulled.
Old 04-09-2013, 08:02 PM   #27
kc0rpm
OK, looks can be deceiving. I am inclined to believe that you are correct and that part number is for an Xb as it is at least half an inch too small in diameter.
Old 04-09-2013, 08:46 PM   #28
It's absolutely amazing that finding a simple part could be so hard.
Does this look correct for the measurements?
Shaft Size: 1.378 in. (35 mm.)
Housing Bore: 2.48 in. (63 mm.)
Outside Diameter: 2.491 in. (63.28 mm.)
Width: 0.394 in. (10 mm.)
Old 04-09-2013, 09:40 PM   #29
kc0rpm
Yeah, no kidding. I was forced to put the old seal back in as I have to have the car back on the road. I'm just hoping it doesn't leak too bad as putting that old seal back in is probably the worst option. On another note I do have to say that royal purple gear oil is like night and day compared to the cheap stuff.
Old 04-10-2013, 09:23 AM   #30
kc0rpm
Well after another trip to the dealer we shall see what we receive tomorrow. Hopefully it is the right part as I about at my wits end with this seal but now I don't have a choice but to replace it. Stupid car repairs are never as simple as they should be.
Old 04-11-2013, 06:45 PM   #31
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
This is definitely my kind of thread (same problem I am having with needing to replace it)
Are you leaking oil much? I loose nearly quart in 6 months!. Iv just been keeping an eye on it and refilling. How easy is it to DIY? Read through thread that i need to have some tools tho...
Check out my Build thread:
Old 04-11-2013, 07:24 PM   #32
YarisSedan
Drives: 08 Yaris Sedan
The part number you need is 90311-34042 for the left and 90311-34023 for the right Ishino makes it, it should be available at any local parts store not just the dealer. If you still cant get it let me know I have 5 in stock they are about 5 dollars each. (happen to work at a transmission shop)
Old 04-11-2013, 07:48 PM   #33
ezhacker1
ezhacker1's Avatar
so its this then?
Old 04-11-2013, 07:52 PM   #34
YarisSedan
Hah yup thats it
Old 04-11-2013, 08:54 PM   #35
kc0rpm
That may be it but I am very hesitant to say for sure as the on for the xb looks identical but just a little smaller than the yaris one
Old 04-11-2013, 09:05 PM   #36
kc0rpm
I wasn't leaking a lot but I hate leaks and got tired of seeing it every time I changed the oil and inspected the CV boots.
As for diy its not too terribly difficult but a couple of specialty tools are nice and one may be absolutely necessary. A slide hammer is one of the tools that makes the job a lot easier for both removing the axle and removing the seal. The tool that I found I couldn't do the job without was a ball joint seperator such as this http://www.harborfreight.com/automot...tor-99849.html. A simple pickle fork will only destroy the boot and there is not enough clearance between the ball joint and axle for anything else. I tried a similar tool to the harbor freight that I found at a parts store but it wouldn't fit between the bolt and axle.
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
