Old 03-29-2013, 02:07 AM   #19
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Personally, I have the dealership do all the maintenance on the car. It's cheap enough (the maintenance) to not worry about the differential over spending my own time changing the oil. I also want NO excuses from Toyota or the dealership if something does go wrong with the engine that something was done incorrectly on my part.
IIRC, the dealership uses conventional oil. They haven't led me wrong yet.
I'm also noticing an old "friend" starting to troll on this thread.
― Thomas Paine
Old 03-29-2013, 04:48 AM   #20
bairjo
Originally Posted by RedRide View Post
Since the advantage of running synthetics is under adverse conditions, do you really want to leave a filter in for 15k mils under those conditions?
What makes you think that there is any less "blow by", which is the cause of most contaminants, with synthetics ?
Just change the filter at 5000 miles. Also, for cold starts...you can't do better than synthetics. I plan on keeping my Yaris for a long time and run synthetic at the recommended scheduled maintenance time.
Old 03-29-2013, 05:47 AM   #21
Yarflana
Drives: 2008 Base Model
At 100K, I changed to Kendall synthetic and plan to change my oil from here on out, but only when it begins to look dirty and with the highway miles I put on it (25-30k a year), I expect a once a year oil change may due.
Yarflana is offline   Reply With Quote
Old 03-29-2013, 07:00 AM   #22
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
I've never used sythetic oil. I do regular oil change, got new spark plugs, new
drive belt, new battery and tranny oil.My Yaris is rejuvenated.
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
Shell conventional ( $2.17 ) / synthetic ( $3.17 ) at BJs Wholesale : 5/31 > 7/4/12 Hershey DIY / Maintenance / Service 4 08-14-2012 12:04 AM
SHELL conventional / synthetic : $9 off a case at BJs Wholesale Hershey DIY / Maintenance / Service 1 03-25-2012 11:12 PM
BJs Wholesale : SHELL conventional or synthetic $9 off a case ... Hershey DIY / Maintenance / Service 1 01-24-2012 11:42 PM
Used Oil Analysis : SHELL full synthetic 5w-30 (SN/GF-5 ) in the '08 sedan Hershey DIY / Maintenance / Service 4 09-23-2011 12:54 AM
