Old 03-22-2013, 08:25 PM   #1
scgoodie
scgoodie
Drives: 2012 Yaris 5 door
Conventional or Synthetic
I have a 2012 Yaris and wanted to put synthetic oil in it. There was nothing in the manual even mentioning synthetic so I emailed Toyota Engineering. They said that the 2012 Yaris is designed to use conventional motor oil and that I should not run it with synthetic.
I have a friend who has a 2007 and runs synthetic and hasn't had any issues. Any ideas?
scgoodie is offline   Reply With Quote
Old 03-22-2013, 08:31 PM   #2
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
With the sheer amount of oil testing they do on these cars I wouldn't even begin to worry about conventional vs synthetic.
I've run synthetic since 30k miles and I've got a touch over 100k on the ticker.
Basically Toyota Engineering's response should be read like this, we rated the motor for conventional and not synthetic so anything outside of the rating is not recommended.
How you should interpret that is, conventional was good enough to get 10/100k out of the engine you shouldn't need more than that. If your like me and your engine sees a tougher environment than a typical car, synthetic probably isn't a bad idea.
Old 03-22-2013, 08:34 PM   #3
scgoodie
scgoodie
Thank you
Old 03-24-2013, 11:42 AM   #4
esse10
Drives: 2009 yaris 2 door
synthetic
Don't waste your money on synthetic conventional works just fine as long as you keep changing the oil at the regular intervals, put a good brand filter though. my two cents on this. fyi I have other vehicles with 200k miles using conventional and still going. good luck man.
Old 03-24-2013, 05:03 PM   #5
RedRide
RedRide's Avatar
Exactly.
One issue that is hardly discussed is no matter what kind of synthetic oil you use, the filter still should be changed as often as with dyno oils and all the contaminants from blow by, etc still build up.
Synthetics may be a bit better for a high performance engines but are a waste of money for an econo engine like in the Yaris....IMO.
Old 03-24-2013, 11:19 PM   #6
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Originally Posted by RedRide View Post
Exactly.
So getting 15k miles out of a single filter and round of AMSOIL synth is waste of money? On the contrary it will take some smokin good deals to get a better bang for the buck, but I digress seeing as how there are too many oil threads on this forum and others.
Old 03-25-2013, 09:58 AM   #7
RedRide
RedRide's Avatar
Since the advantage of running synthetics is under adverse conditions, do you really want to leave a filter in for 15k mils under those conditions?
What makes you think that there is any less "blow by", which is the cause of most contaminants, with synthetics ?
Old 03-25-2013, 11:21 AM   #8
Hershey
I can get SHELL synthetics under $3.40 a quart or Pennzoil synthetics less than $4 a quart . Not much more than many conventionals . Fine if you wish to use a conventional or a semi-synthetic . The engine seems to be quieter with a full synthetic . Especially at interstate speeds . SHELL conventional can be bought under $2.50 per quart .
Old 03-25-2013, 12:43 PM   #9
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
My Yaris is so cheap to own and run, I go first class with Mobil 1, change every 3,500 miles, and have a magnet in the drain plug which catches everything ferrous.
Old 03-25-2013, 01:48 PM   #10
TOLMACH
Drives: soarer
Where did you buy this magnet?
Thanks
Old 03-25-2013, 02:38 PM   #11
tooter
play every day
tooter's Avatar
Thanks
I had a small cylindrical neodymium (really strong) magnet and simply drilled a hole in the drain plug with a drill press and glued it in with JB Weld. Small magnets are readily available on ebay at very reasonable prices.
At every oil change, I wipe off the extremely fine black metallic residue attached to the magnet. That's the thing about magnetism, there is no size limit on the ferrous metal particles attracts and captures. The residue is so fine that when you rub it between your fingertips, you can't even feel it.
Magnets on drain plugs are common aftermarket items installed on motorcycles where the transmission and engine share the same oil reservoir.
Old 03-25-2013, 02:50 PM   #12
I've been using Amsoil ever since year 2 of owning my car new. There was a year where I using MANN oil filters because Amsoil temporarily discontinued their EA oil filters for the Yaris, but I changed those every 7,500 miles. With the Amsoil EA oil filter, I just changed it (and the Amsoil engine oil) every 1 year since I never drove more than 13k miles a year.
I also used nothing but Chevron gas, and clean out the engine once a year using Seafoam. I just checked my PCV last week, and it was still in very good condition, even after 90,500 miles on it. Rattled freely, and I just cleaned off the little build that was on it. My engine compression when I checked it around 70k, I believe, was near new specs.
I think Amsoil has served me and my car very well. I'll continue using it.
Old 03-25-2013, 04:17 PM   #13
fnkngrv
fnkngrv's Avatar
I have no response...other than you also made a comment that installing an adjustable rear spoiler/wing on a fwd is a misguided idea.
Old 03-25-2013, 04:22 PM   #14
fnkngrv
fnkngrv's Avatar
Last thing that I have to say on it for you in this thread is that as long as it meets API standards then you are fine. Hearing that you received a correspondence from behalf of Toyota Motor Corp actually telling you this leaves me to pause because that is pretty ballsy to say the least...whomever actually clicked "send" is lucky they have a job still because they could cause Toyota to have their ass brought back into the courtroom again. At least the responder wasn't stupid enough to actually say that it would void your warranty.
For your decision you can just reference below on it and make your own choice. There has been plenty of arguments for both conventional and Synth for the last 30+ years in automotives.
http://autos.jdpower.com/content/con...motor-oils.htm
Old 03-26-2013, 12:59 PM   #15
RedRide
RedRide's Avatar
You're taking comments out of context now to bolster a "misguided" position without even addressing the post you responded to??
As you said you, "I have no response to that....."
How about addressing the issues at hand instead of spending your efforts in trying to kill the messengers.
Old 03-26-2013, 01:23 PM   #16
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
Are you the type of person thats going to keep your yaris for 10~15 years, exceeding 200k~250k miles? If so, than 100% go synthetic! But if your going to sell/trade in your Yaris at 4~7 years, you wont need synthetic.
UberSilver is offline   Reply With Quote
Old 03-28-2013, 10:21 PM   #17
YarisSedan
Drives: 08 Yaris Sedan
http://www.ebay.com/itm/Magnetic-Oil...8628e5&vxp=mtr
Old 03-28-2013, 10:25 PM   #18
YarisSedan
I too use a magnetic drain plug and have been running synthetic since 10k miles. I change my oil once a year and use either amsoil or royal purple whichever happens to be the cheapest at the time and a K&N oil filter. When i drain my oil out it still looks clean.
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
Shell conventional ( $2.17 ) / synthetic ( $3.17 ) at BJs Wholesale : 5/31 > 7/4/12 Hershey DIY / Maintenance / Service 4 08-14-2012 12:04 AM
SHELL conventional / synthetic : $9 off a case at BJs Wholesale Hershey DIY / Maintenance / Service 1 03-25-2012 11:12 PM
BJs Wholesale : SHELL conventional or synthetic $9 off a case ... Hershey DIY / Maintenance / Service 1 01-24-2012 11:42 PM
Used Oil Analysis : SHELL full synthetic 5w-30 (SN/GF-5 ) in the '08 sedan Hershey DIY / Maintenance / Service 4 09-23-2011 12:54 AM
