Old 04-04-2016, 12:14 PM   #1
Rocketyaris
Rocketyaris's Avatar
Drives: 2010 Yaris 3 door
I bought Starnill 72w LED headlight bulbs on Amazon.com for $65 bucks. They are awesome so far.
Rocketyaris is offline   Reply With Quote
Old 06-13-2017, 10:05 PM   #2
heeroyuy01195
Post count means nothing.
Drives: AW11, NCP91, Old Motorcycles
Bringing this back. Wanted to see if anyone has tried LED's since this was posted. I drive on a lot of highways at night that don't have street lamps. Would like some extra lumens if possible. HID's are a no-go for me, too many issues with them in the past and the high beam usually doesn't work or stops working shortly after install.
heeroyuy01195 is offline   Reply With Quote
Old 06-13-2017, 11:34 PM   #3
What brand HIDs did you get? I've had two Morimoto Elite ones from The Retrofit Source (on my second Yaris now), and they work great. Had to warranty the kits a couple of times, but after receiving the new parts, they work flawlessly in low and high beams.
If you want LEDs, I'd suggest waiting for VLEDs to finish their H4 Micro Series headlight.
http://www.vleds.com/shop-products/l...hts/micro.html
The H4 won't be listed yet as they are still working on it and a few other bulb types.
Old 06-14-2017, 05:04 AM   #4
miiser
miiser's Avatar
Drives: yaris 2009
Keep in mind that HIDs are much more brighter that leds. But leds are more clear than HIDs. I think the best solution is project headlights but there require some skill to fit them.
One thing that worries me to is that you have to cut the rubber seal to install the leds because otherwise they don't fit
miiser is offline   Reply With Quote
Old 06-14-2017, 11:08 AM   #5
heeroyuy01195
My very first HID was some cheap eBay one, and never again did I decide to buy a cheap item.
The Micro Series supposedly lines up the light intensity to that of a halogen bulb, so I'm assuming it'll be good.
I'm going to keep an eye on the Micro Series kit. I've had HID's from ebay, some from more reputable sources, some from local sources, just never had luck with them. I also didn't like the spread pattern without a projector. If we had an OEM projector headlight option then I would likely try them again.
Originally Posted by FunctionSpec View Post
I tried a set of Nighteye 80w LED bulbs and they were no good. Light output was low and didn't have any range. People with halogens driving next to me had better range and output. Color temperature was a bit off looking, was a bit too blueish. Threw back on my HIDs and man what a difference, it was like the sun vs the moon. Going to stick with HIDs from now on. I have a ballast from Xenon-Vision that is still going strong after 10 years and a set of cheap Bi-Xenon H4 bulbs from eBay going on 3 years now. I would stay away from Xentec, those are no good.
I'll keep these in mind but still don't want to use the HID's without a projector because of the spread pattern.
Originally Posted by yariseggvvti View Post
26inch LED light bar, LED foglamp with three led bulbs and 43k HID headlamp.
Can you show a picture of the light pattern and distance?
I know the HID's are much brighter but to really get full use out of them, a projector setup is ideal, like you said. I absolutely hated the spread pattern when I had the HID's and I hated being flashed by oncoming vehicles. I don't trust myself to reseal the headlight properly so I'm going to skip the retrofit option lol. I suppose in a way the LED setup would probably be best in a projector but I'm still curious to try them.
I was looking into getting these
http://www.xenondepot.com/h4-philips.../12953bwx2.htm
My main drawback is that it's rated at 1000 lumens low beam which is what my current OSRAM Night Breaker Unlimiteds are rated at. The spread on those philips bulbs looks quite close to a standard halogen bulb but slightly brigher. I know they aren't meant to be a super bright option, but rather an "upgraded" OE replacement. Maybe I'll just go old school and mount two 6" KC lights in my front grill
Old 06-16-2017, 12:27 AM   #6
miiser
miiser's Avatar
Drives: yaris 2009
Has anyone ever tried LED headlights?
These are extremely expensive mate. Literally. You won't even see an extreme deferent between these and the regulars. For me this kind of money for 2 headlights is absolutely out of the question. I don't know what's your headlight status (I mean how foggy they became over the years), but in the same amount of money you can replace the entire headlight module, and buy 2 new oem valeo's. that's better if your plastic has became foggy after so many years.
Led light-spread isn't better than HIDs. In fact HIDs has better light spread I think.
Our headlights are designed for regular lamps anyways.
But really, my opinions is: don't give so much money for these. It isn't worth it by any means.
There are decent leds for about 1/3 of the price. Starting from about 70€-$ you can get a decent quality. After all lights are consumable products. And you can't predict how long they will last
Old 06-16-2017, 11:46 AM   #7
heeroyuy01195
I hear ya, I'm still up in the air on this. Going to see what happens with those slim LED's that Kaotic mentioned. Leaning towards just sticking 2 lights in my front grill somewhere for the extra candle power.
Old 06-14-2017, 12:05 AM   #8
heeroyuy01195
I've gone through a bunch of different brand HID's over the years and eventually about 3 years back I switched back to halogens.
vled has a headlight bulb listed for the Yaris but it looks huge-normous so I'm guessing it's best I wait for the micro series like you said. Curious how the spread will be on them vs. a halogen or HID. Time to consult the google!
Old 06-14-2017, 12:11 AM   #9
Old 06-14-2017, 01:05 AM   #10
FunctionSpec
Super Newbie
FunctionSpec's Avatar
Drives: 2007 Yaris Liftback White
FunctionSpec is offline   Reply With Quote
Old 06-14-2017, 02:32 AM   #11
yariseggvvti
Drives: Yaris Hatchieback
yariseggvvti is offline   Reply With Quote
Old 07-26-2017, 12:02 PM   #12
Cezza07
Drives: 2014 Toyota Yaris L
I'm getting some HIKARI LED headlights on Saturday, along with Reverse (back up) lights and internal lights.
I have OPT7's in my other car and they are bomb....
SOOO much brighter than my old halogens, secondary to this it lights up the highway signs/cat eyes/lines and such a lot better.
Brake lights have been swapped out with LED's, next step is the indicators/flashers.
I will post before and after pictures once completed.
2014 Toyota Yaris L
Cezza07 is offline   Reply With Quote
Old 07-26-2017, 01:18 PM   #13
jonce2001
Drives: yaris TR 09
yes ...most are not great
BUT!! Try ATSHARK 110w 10400lm H4 tricky to fit as space is tight for fingers.
remove bulb, replace with a bulb base and clips in with original springs, and led unit
screws in, get a buzzing noise of the fan coolers but dont hear it inside
They are AWESOME!!!!! mind blowingly bright!!!!!
jonce2001 is offline   Reply With Quote
Old 07-26-2017, 08:52 PM   #14
Yaris709
Drives: 07 yaris
I have a set of led's I bought from a local supplier and they were the top notch lights they had. Put them in my yaris and they're as dull as f*cking candles. Look bright looking at the car. Other people have had excellent luck with them. I had a set of led's before as well (more lower end) and no difference. My philips xtreme vision halogens are easily 2-3 times brighter. I don't think the yaris reflectors take well to led's in my opinion
Yaris709 is offline   Reply With Quote
Old 07-26-2017, 08:55 PM   #15
Yaris709
Drives: 07 yaris
And I purchased an led light bar from amazon, just a cheap $50 23" cree light and it's like daylight.
Old 07-28-2017, 12:06 AM   #16
heeroyuy01195
Can you put up some pics on where you mounted it? I've been using some osram nightbreakers and they're definitely a huge improvement over stock. Still unsure about LEDs
Old 07-28-2017, 04:51 AM   #17
Yaris709
Drives: 07 yaris
I have one of those licence plate brackets bolted on the front bumper directly. Gotta use a few big washers to get the 23" to fit. It's a pain to aim the light bar but doable. I'll get a few pics in the next couple days and post here. You'd be better off with a light bar than the led headlights in my opinion
Old 07-31-2017, 11:50 AM   #18
Cezza07
So the HIKARI H3 LED headlights I bought are frikkin AWESOME.
Highly reccomend... And on Amazon right now they have a deal where you get a free pack of LEDs with a headlight purchase. Which are also very good.
With one purchase, I got my reverse lights, forward side lights, headlights, and the trunk light. Looks so good.
(I have also replaced the brake and interior lights, all I need to do now is replace the flashers)
2014 Toyota Yaris L
DIY: Yaris LB Halo Led Projector Headlights goku87 DIY / Maintenance / Service 37 11-15-2013 06:23 AM
Sonar DRL LED Projector Headlights geniusmusicman Cosmetic Modifications (Exterior/Interior) 21 07-22-2012 11:16 PM
DIY LED Strip under the door panel charleschia1986 DIY / Maintenance / Service 19 11-05-2011 07:49 PM
Where to get Sedan Projector Headlights and Led Tails c4c Cosmetic Modifications (Exterior/Interior) 1 05-19-2009 12:38 AM
Hella Headlights and LED washer nozzles spkrman Photo-Video-Media Gallery 8 04-18-2007 10:54 PM
