Old 05-08-2013, 12:38 PM   #1
Custom Instrument Cluster LED Color Change Service
I have done LED color changes for a couple of people recently, so I figured I would go ahead and open this service to the rest of the community. The 09-11 clusters are the best for modifying, as the speedometer is a single color, fed only by the LEDs. The 06-08 clusters have some either red or blue trim printed into the plastic, so that portion will not change color.
I can standard colors, like white, blue or red, or I can do a wide variety of custom colors, using a trick that I figured out for also being able to change the color of the clock (on non-tach cluster) to match (as the clock uses a VFD display, rather than LEDs). So, almost any color you can imagine I can do.
If you are relatively local, we can schedule it where I do it while you wait (it takes about an hour or so for me to do one). If you are not local, you can either pick up an extra cluster off ebay for me to mod, or I can potentially mod one of my extra ones and have you ship your original one back to me. I can also reprogram the odometer for an extra fee, so matching your mileage on a swapped cluster is not an issue.
Cost (+ return shipping, which typically runs under $15 within the US):
Color change only: $100
Odometer reprogramming only: $50
Color change and odometer reprogramming: $125
Here are some samples:
Blue:
White:
Custom Violet:
Custom Green:
change, cluster led, color, speedometer, tach
WTD: ECM, Instrument Cluster, Headrests, Quarter window chrisjaldin Willing to Buy by private party 8 09-02-2011 11:12 PM
Cruise Control - 07/08 Sedan - Instrument Cluster CB900F2 DIY / Maintenance / Service 4 02-23-2011 07:03 AM
Sedan Instrument Cluster to LB Instrument Cluster Malaya1221 Cosmetic Modifications (Exterior/Interior) 2 12-02-2008 10:05 PM
Instrument Cluster Swap thepaidtraveler Cosmetic Modifications (Exterior/Interior) 28 11-24-2008 09:53 AM
instrument cluster swap S -> LB elo79 Performance Modifications 1 12-21-2006 10:22 AM
