Old 05-11-2014, 11:15 AM   #19
white_rice
white_rice's Avatar
Drives: 2008 Toyota Yaris LE
Send a message via MSN to white_rice
Rings should come with the shroud.. Mini and regular fits on hatch but sedan I believe had to be mini...
Thanks Marcus.. but whats the difference between the 3 Apollo styles? I just want to make sure I put the order through right the first time so I'm not re-ordering things a second time around.. lol
white_rice is offline   Reply With Quote
Old 05-11-2014, 01:44 PM   #20
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
Apollo has 3 different design you choose which one you wanna run on ur kit..
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!!
"Horsepower is how fast you hit the object. Torque is how far you move that object.."
Old 05-13-2014, 12:32 PM   #21
white_rice
white_rice's Avatar
Thanks Marcus.. and all 3 applications fit fine on our vehicle? Did you also order a full kit from this website?
Old 05-19-2015, 11:10 AM   #22
marcus
toyota
marcus's Avatar
Led halo didn't last too long too bad you can't see yours..I placed mine outside and almost 75% of the LEDs are gone after 12 months
Old 09-22-2015, 07:47 PM   #23
oohcory
Oohcory
Drives: 12' Yaris 2dr Liftback
Send a message via AIM to oohcory
Any problems with install at any point? I've installed mine and the headlights do not work. Unless the brights are on. And then at that point only the drivers side emits light while the passenger side flickers. Plus my driver side turn signal is on continually (not blinking, just on) any suggestions would be helpful.. I tried calling TRS but they are currently closed.
oohcory is offline   Reply With Quote
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal V70R_Blackbrick Cosmetic Modifications (Exterior/Interior) 26 11-27-2013 10:14 PM
DIY: Yaris LB Halo Led Projector Headlights goku87 DIY / Maintenance / Service 37 11-15-2013 06:23 AM
DIY: Adding LED turn arrows to side mirrors my2sense DIY / Maintenance / Service 10 05-28-2012 02:16 AM
DIY LED Strip under the door panel charleschia1986 DIY / Maintenance / Service 19 11-05-2011 07:49 PM
