Old 02-08-2014, 12:39 PM   #19
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Yea I was going to say, the MI manifold sits wayyyy close to the hood latch so idk if the spacer would push it too far, if anyone around you cares to test fit id be interested
are you planning on making any TB spacers?
No. Because they don't change the operating parameters of the intake manifold enough to matter. All a throttle body spacer does is to slightly enlarge the plenum volume. If the intake runners are already reading open air at the plenum, making it larger doesn't make any difference.
In contrast making the intake runners longer alters the frequency of the reflected intake pulses which makes them resonate at a lower frequency (lower rpm). That's what lowers the torque peak in the rpm range.
Greg
Old 02-08-2014, 12:43 PM   #20
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
see ive heard adding space their does change the parameters of how air flows in through the mani and also they help with dissipating heat allowing the air coming in to stay slightly cooler.
Old 02-08-2014, 12:49 PM   #21
tooter
play every day
tooter's Avatar
While that might be true... I don't believe that a spacer would make enough of a difference to matter. Intake air temp wouldn't be any cooler on a plastic manifold no matter what spacer was on it. Heck, the throttle body is even heated, so disconnecting the radiator fluid hoses would make more difference in cooling intake ait than a spacer.
Greg
Old 02-08-2014, 12:51 PM   #22
tooter
play every day
tooter's Avatar
Production Estimation List
1. BEEF
2. Fredovvti
3. dragoonmc
4. jjwitter
5. Klink10
6. HANZO_187
Old 02-22-2014, 05:14 PM   #23
HANZO_187
#CarFiend-HANZO188
Drives: 2011 Toyota Vios
I just wanted to get an updated about these Mani-Spacers.
I'm very interested in how you even came to make all this stuff! I have to put mine on hold in the mean time till I find out what my class will be if I installed it for Auto Cross.
Please, keep us updated.
-HAN
I N S T A G R A M- @Hanzo_Stmpng_Grnds
x-Check out my build thread-x
HANZO's Build Thread
HANZO_187 is offline   Reply With Quote
Old 02-22-2014, 07:28 PM   #24
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
I actually need to put mine on hold too. i've been playing with numbers and am seriously looking into getting a BRZ.
I do still really like the concept and idea.
Old 02-22-2014, 11:55 PM   #25
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Im definetly down for one. Just when exactly ill have the money is pending what i buy to replace my other car. I still need to finish the proper tooter.
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 02-23-2014, 01:09 AM   #26
tooter
play every day
tooter's Avatar
It's just a hobby I enjoy doing in my spare time.
The whole process from idea to finished product is so much fun. It's like an adventure. First to come up with a concept, and then a design, and a prototype, and then dyno testing, and then production, and then sales.
-HAN
Sure will, HAN.
None of the names on the list mean a binding commitment. It's just to give me a rough idea of how many people might be interested so that I can estimate how many to have machined. Another production run of tooter II.VII Tacoma intake manifold spacers is still in the works right now awaiting for some new tool bits to arrive, so the Yaris spacers will also be coming soon. The method of machining the spacers is constantly being refined as we go.
Greg
1. Fredovvti
2. dragoonmc
3. jjwitter
4. Klink10
Old 02-23-2014, 02:31 PM   #27
Astroman
Modded Moderator
Astroman's Avatar
Tooter I have a dc sports header, magnaflow exhaust, aem cai and a 1zz tb. Would this help me get back some of the low end torque I lost with the dc? I can't afford the TRD header thars for sale and wondering if this would help.
Old 02-23-2014, 04:50 PM   #28
DJYojimbo
Drives: 2012 Grey Toyota Yaris SE
@astroman, you lost low end torque with the dc sports header?
Upgrades: AFE SRI. Tanabe Touring Medalion Axleback exhaust. Micro Image OEM Sized Lightweight Pulley. DC Sports header.
DJYojimbo is offline   Reply With Quote
Old 02-24-2014, 03:02 AM   #29
tooter
play every day
tooter's Avatar
Yeah, I also don't see how a DC header could hurt your low end performance, Astro. Did you also delete any cats or install a larger mid pipe?
I only know the difference logged between the before and after dyno runs with the spacer as the only change and nothing else.
This same equipment was used for both runs:
1. SRI with BLOX velocity stack air filter
2. Weapon R 4-2-1 header
3. MicroImage MagnaFlow axleback exhaust
Red: no spacer
Blue: tooter I.V spacer
Greg
Old 02-24-2014, 07:10 AM   #30
1.5
Form>Function
1.5's Avatar
Well that is still promissing. Big increase in torque for our little motors.
Old 02-24-2014, 02:40 PM   #31
Astroman
Modded Moderator
Astroman's Avatar
I was getting my info from the TRD header sales thread which there was discussion that the TRD header wouldn't lose low end torque vs the DC Sports header.
Old 02-25-2014, 12:17 AM   #32
tooter
play every day
tooter's Avatar
Yeah, the TRD is a very well thought out design, and was likely refined by dyno testing to get the very best configuration.
What works against all of the Yaris headers is that the available space to make it a bolt on part is so damned short.
Man, I freaked out when I saw that someone actually folded the runners to make a long tube header fit into the SAME space as the stock short tube header on my Tacoma. It's by far the most clever bolt-on exhaust design I've ever seen!
The runners are 30% longer than the stock header, and are all equal length.
Greg
Old 02-25-2014, 07:00 AM   #33
BEEF
BEEF's Avatar
If i may be so bold, what did that header cost?
Old 02-25-2014, 12:50 PM   #34
tooter
play every day
tooter's Avatar
It was $473 including shipping from LCEPerformance.com. I installed one within a week of buying the truck. The fit and finish are flawless.
Greg
Old 02-25-2014, 03:44 PM   #35
BEEF
BEEF's Avatar
They made awesome use of space there. The price isn't ridiculous either.
Old 02-26-2014, 12:47 AM   #36
tooter
play every day
tooter's Avatar
As far as I'm concerned, I more than got my money's worth.
The stock downpipe didn't need to move one millimeter to accept the header.
On the dyno, the header lowered the torque peak by 650rpm from 3,800 rpm down to just 3,150 rpm.
Greg
tooter's manifold adventure... tooter Performance Modifications 1465 07-31-2014 08:11 PM
stock scion xa exhaust and intake manifold and others taman86 Items for Sale by private party 0 09-27-2012 02:39 PM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 08:03 PM
