Old 08-25-2014, 07:26 PM   #1
jayman
Drives: Yaris Sedan
Stock lug nuts work, but I would not want to run them for very long. Mini lugbolts (shown below) are 14mm (versus our 12 mm lugs), so there is quite a bit of slop to the holes, which results in a significant portion of our OEM lugnut taper sitting in the hole.
Attachment 53483
The lugnuts which I referred to in the link in post #2 above are shown below. They have a much larger tapered section than our stock lugnuts and the "bulge" fills the 14mm to 12mm gap. They were difficult to find since, as mentioned above, most conical bulge lugnuts are not metric.
Hey How long did it take you to get these lug nuts it is showing online that they want even ship until 9-6-14 ?
jayman is offline   Reply With Quote
Old 08-25-2014, 07:30 PM   #2
jayman
Drives: Yaris Sedan
How long did it take to get these lugn
ut online it is showing me they will not ship until 9-6-14
Old 05-10-2014, 03:28 AM   #3
ivanstepul
Drives: 08 hatchback
The picture that I posted is with stock lug nuts but I ride after market acorn style lugs I got from ebay, I don't know if the ones I posted are the right size but it's that style . And some recent pics with the new wing.
http://www.ebay.com/itm/LUG-NUTS-BUL...item3cbf8f4802
ivanstepul is offline   Reply With Quote
Old 05-11-2014, 10:08 PM   #4
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
that looks really nice
Old 05-13-2014, 07:49 PM   #5
SKurj
Drives: 09 Yaris 3dr HB, BRZ
Big fan of the mini wheels myself.. but one question how heavy are they? Had a set lined up but he wanted too much for em, set of 4 with only 3 decent tires for $400. Didn't realize there was more to the fitment than just hub centrics though..
SKurj is offline   Reply With Quote
Old 05-13-2014, 08:19 PM   #6
It varies by rim type, but the 15" 5 spoke mini wheels that I ran for a while were about 4lbs lighter per wheel than steelies.
Old 05-10-2014, 07:18 AM   #7
Your car is looking good. Those bulge-type lugnuts should be OK. At least the larger conical section makes full contact with the taper of the rim hole, whereas with the stock ones there is very little contact area.
Old 05-11-2014, 11:44 AM   #8
ivanstepul
Thanx
Old 05-19-2014, 10:11 AM   #9
3rdSEman
3rdSEman's Avatar
Drives: Black 2012 SE manual
quote> those bulge-type lugnuts should be OK. At least the larger conical
stock ones there is very little contact area <quote
Thanks for the advice CT..
I couldn't locate any extended tip nuts which would fit my wheels.
The 0.625" extended tip diameter would not clear my 0.595" rim thru-hole.
So I similarly purchased bulge-type nuts which do cover the 0.800" outer conical area.
3rdSEman is offline   Reply With Quote
Old 05-11-2014, 01:02 PM   #10
kimona
kimona's Avatar
Drives: 2014 White VITZ
MINI wheels look great on our cars!
Old 05-19-2014, 10:50 AM   #11
OK. So, you have a set that used 12mm lug bolts. Some of the mini rims use 12mm and others 14mm. The ones that I had were from a mini with 14mm lug bolts.
Old 05-19-2014, 10:58 PM   #12
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Bronze on blue looks good so will white tire size good for saving gas :)
Sent from my XT1032
Old 05-20-2014, 09:21 PM   #13
end user
GRO H2O
Look like I'm gonna have to order lug nuts online as no local tire/wheel shops carries anything lug nut wise. Will be $78 CDN after shipping/border extortion fees for 20 (only packs of 5) of these http://www.jegs.com/i/Detroit+Wheels...395-5/10002/-1
Will post back with photos.
end user is offline   Reply With Quote
Old 05-21-2014, 12:36 AM   #14
JTDBT903
JTDBT903's Avatar
Drives: '08 SEDAN 5 SPD.
Set of 20 with valve stems! $25.99
http://www.jegs.com/i/Detroit+Wheels/306/5395K/10002/-1
JTDBT903 is offline   Reply With Quote
Old 05-22-2014, 04:13 PM   #15
end user
GRO H2O
Originally Posted by JTDBT903 View Post
I got 4 sets of the 5 lug kits, didn't need no chrome valves etc.. I don't know about Jegs though lol I had to optioms for shipping. One was standard ground which I know usually from the US is about 5-12 days or the 2 day shipping. Well lol it was 2 days to get the shipment confirmation email and it still gonna take 9 days LOL to get the lugs. So for $8 more I get to have standard shipping anyways.
Looking at Canadain online parts market looks like there's a void to be filled as there's not much in Canada for online car part retailers. WIsh I had a mil or two to start one.
Old 05-23-2014, 12:44 PM   #16
end user
GRO H2O
LOl I stand corrected, they arrived yesterday. I broke my torque wrench so can't put them on today and will have to take them to a shop tomorrow morning.
Old 05-27-2014, 08:27 PM   #17
end user
GRO H2O
Finally got around to it. En not sure if I like them on a stock height car :P would have been much nicer the they came in 16".
The rear to tuck in quite a bit so maybe a spacer will be needed to make it more flush.
Old 05-27-2014, 08:44 PM   #18
I love the phone dials on a Mini, but you're right - They do look a little small on a Yaris. Maybe if they were white, it would give the illusion of them being larger?
Question about these rims. Bar_Red_Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-09-2011 08:54 PM
My 17" alloy rims and Kumho tires... will swap for your original wheels! AutoWashCars NY / NJ/ CT / PA 5 02-08-2011 07:38 PM
RIMS a Noob-toob question =] donchae Wheels, Tires and Suspension Forum sponsored by The Tire Rack 45 10-17-2010 06:11 PM
Question about Rims MrJester Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 03-06-2007 10:16 PM
hufeisen rims JustYYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 01-17-2007 03:16 PM
