Old 04-16-2014, 09:52 PM   #19
bostssgt
Drives: toyota echo
post it!!!!! my alphabet goes ABDC
bostssgt is offline   Reply With Quote
Old 05-01-2014, 03:00 PM   #20
ok guys, I can get Web cams made and have a set going out for turbo applications now.
$700 for a pair, plus a core charge until we get your stock cams back. I will try to keep a pair on my shelf for your turbo 1NZ builds.
Old 05-04-2014, 08:37 AM   #21
bostssgt
Drives: toyota echo
wow!! great news! this will be a regrind? bucket shims availlaible? can you post the timming of the cams?
thank you
Old 05-04-2014, 08:49 AM   #22
bostssgt
Drives: toyota echo
(found on MI .pdf http://www.microimageonline.com/down...als/Engine.pdf)
stock yaris 1nzfe (i belive these are at 0 lift!?!?)
intake-----Open -7deg - 33deg BTDC
-------------Close 52deg - 12deg ABDC
Exhaust---Open 42deg BBDC
------------Close 2deg ATDC
Old 05-04-2014, 01:18 PM   #23
exileddeus
exileddeus's Avatar
Drives: '10 Yaris HB
That's a really good price. Wish there was a mild N/A option. Lol, i'd love to turbo but being my daily I really need it to pass emissions.
exileddeus is offline   Reply With Quote
Old 05-13-2014, 07:03 PM   #24
Scipher
Drives: 2008 Toyota Yaris
I'm in the process of lining up and pricing out the necesseties in my project. Currently its stock, new spark plugs haha. My intentions are to mod all the way up to a turbo and significant weight reductions so i can capitalize on the power to weight ratio. Im glad there are more options then just JUN, 1000$ is a tough pill to swallow. Although id be curious to see what the actual differences in longevity, and preformance are if there are any.
Scipher is offline   Reply With Quote
Old 05-13-2014, 07:47 PM   #25
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Honestly if you go turbo weight in this car becomes moot. Neither of the two platforms weight over 2400 lbs anyway. Toyota did a really good job on weight.
sent from my m-o-b-i-l-e
Old 05-13-2014, 08:01 PM   #26
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
but if you can turbo it up to 300whp or more and then drop the weight to around 1800lbs you have a small rocket ship
Old 10-08-2018, 01:59 PM   #27
aldorei
step by step, toungue out
Drives: 1NZ-FE MarkI Xp10 Yaris coupe
hey, it's the 2NZ-FE camshafts same compare to 1NZ-FE camshafts?
aldorei is offline   Reply With Quote
Old 11-20-2018, 08:41 PM   #28
suprf1y
suprf1y's Avatar
Drives: 05 Echo
I'll try this one more time.
Does anybody know the stock cam specs?
suprf1y is offline   Reply With Quote
fog light options charleschia1986 Cosmetic Modifications (Exterior/Interior) 3 11-13-2009 04:00 PM
TRD Options S1L3N7 D3A7H New YARIS Purchase Forum 26 01-20-2009 01:52 PM
OEM Aerodynamic options (to 'S' or not to 'S') invol Fuel Economy Forum 6 12-02-2008 10:29 PM
Which options are dealer installed? grampi New YARIS Purchase Forum 4 07-30-2007 01:23 AM
