Old 04-13-2014, 01:19 PM   #1
bostssgt
Drives: toyota echo
camshaft options for 1nzfe
hi! i want to know what are my option for camshaft on my 1nzfe,
plans are turboing (td04h-13t from hyundai genesis intercooler from lancer ralliart 09+) with cp 9:1 cr
i have read a post here http://www.yarisworld.com/forums/showthread.php?t=43928
jun cams seems nice but too expensive
in my suzuki swift i have cams from supfly a member on www.teamswift.net that does regrind for 300$ with core exchange
found on the internet that some here asked him to do 1nzfe cams, asked him myself and he said its not worth it on that valve train setup (bucket shims)
so what are my option?
thank you
bostssgt is offline   Reply With Quote
Old 04-13-2014, 02:01 PM   #2
NT05
Drives: 1nz-fe
You have one solid choice: JUN
Other than that you will get what you pay for. Regrinds for street use = time bomb.
Especially after looking around and have found no one with any real reliable proof for regrinds on the 1nz-fe.
Ferrea has complete valve train with springs lockers and seats that work for high rpm and new cams.
The JUN cams are built to last I have a set and the quality is fantastic.
NT05 is offline   Reply With Quote
Old 04-13-2014, 02:47 PM   #3
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Are you a JUN spokes person? Last 5 posts you made have been praising JUN. Granted, they are a good company, but they are a bit pricey. I know a few people who have used regrinds with no issues. Its all about the tune. JUN cams can do the same amount of damage as stock cams can if its not tuned correctly.
But yes. JUN is the only company that makes aftermarket cams for the 1nz. Keep in mind, the profile on those are aggressive and you will have to knotch out the head for clearance.
-Derrick-
Old 04-13-2014, 03:25 PM   #4
NT05
Drives: 1nz-fe
LOL, not a JUN spokesmen but if I'm going to spend money it's only going to be on quality proven parts. (no matter the cost)
I'll be sending my head out to get machined properly and have the full treatment done.
Old 04-13-2014, 04:30 PM   #5
ilikerice
ilikerice's Avatar
So what vehicle are you building? Yaris LB, Yaris Sedan, xA, xB?
-Derrick-
Old 04-13-2014, 05:16 PM   #6
NT05
Drives: 1nz-fe
well my family has a rental yard that someone never paid for their spot in the yard for about 6 months so I acquired a Xb.
Old 04-13-2014, 06:50 PM   #7
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Web Racing cams can do 1nz cams. If you are concerned whether or not they do good work then all you have to do is talk to ScionCrew on here. They did the cams in his xB that ran 11s or 12s in the quarter running almost 300whp and 20psi of boost. Believe too that his rev limit was set at mid 7000s.
sent from my m-o-b-i-l-e
Old 04-14-2014, 07:02 AM   #8
bostssgt
Drives: toyota echo
....rev limit was set at mid 7000s.
7500 rev limit will be good for me too with the 4age blacktop franksmission that i'm building
Old 04-14-2014, 05:59 PM   #9
Rigaud
Drives: 2009 Yaris
Regrinds are like a band aid or playing russian roulette. It's a hit or miss and always has been, not worth from my own personal experience. Only one way to do a job right.
Some may disagree and not like my opinion but been there and it isn't pretty when things go boom.
2009 Toyota Yaris (Little toy)
2002 Audi A4 Avant Quattro 3.0L (Big boy toy)
1998 Subaru Legacy GT 2.5 (winter & DD)
Rigaud is offline   Reply With Quote
Old 04-14-2014, 11:21 PM   #10
NT05
Drives: 1nz-fe
Regrinds are crap, they will never hold up like a billet or forged piece. Regrinds are generally used when something is just not available. In this case the only reason to not use real made and proven cams from JUN, is simply you can't afford them. In such case you really shouldn't be building a race motor to begin with. Because if this one mod will leave you broke than the rest of the build is going to suffer as well. As well as when a regrind brakes so does the rest of your motor and then your just out thousands anyways. So build it right and do it once. This is my own opinion and experience from other imitators like GUDE Performance. I figure if going to do something do it right the first time.
Old 04-15-2014, 07:04 AM   #11
bostssgt
Drives: toyota echo
Thumbs down
this is not a "regrind cam, good or bad?" thread!
Old 04-15-2014, 08:45 AM   #12
ilikerice
ilikerice's Avatar
Sorry, but I dissagree. One can still build a motor with top parts and pass on the cam upgrade by just using stock cams.. Pick and choose your parts based on your goals. A motor can still be just as reliable and perform just as good if not better by using the stock camshaft
-Derrick-
Old 04-15-2014, 08:56 AM   #13
NT05
Drives: 1nz-fe
Sure I agree you can still build a good motor with stock cams BUT Definitely NOT better. Cams are the heart of the motor, they dictate how well the motor breaths. And since this thread is about cam options there really is only one choice: JUN . No one else makes a proven reliable set of cams for the 1nz other than JUN. Sure you can still build a decent motor without them but you'll never get to that big boy power without them.
Old 04-15-2014, 08:58 AM   #14
ilikerice
ilikerice's Avatar
As for the OP. I think you got your answer.
-Derrick-
Old 04-15-2014, 07:02 PM   #15
scioncrew
scioncrew's Avatar
Drives: SCION tC
Send a message via AIM to scioncrew
WOW! Regrinds are not that bad. Jun is a good brand but their price on the cams are way too high. Most cam manufactor cam prices are from 800-1000 for a set of cams. so far Jun and WEB cam are the only companys making cams for the 1nzfe motor. I my self would go with Web cam it is a very good company reasonably priced i highly recommend them. My motor has been ranning their cams sense 2005 and havent had any problems. hope this helps call Web cams see if they wil still make them and get a quote
Art
05 Scion tC allmotor 350+ hp 9.34@144mph
05 Scion tC sfwd 880hp 9.96@147mph
05 Scion xB 280hp 12.97@104mph
07 Toyota Yaris 357hp 12.80@107mph
scioncrew is offline   Reply With Quote
Old 04-16-2014, 01:47 PM   #16
^ thanks Art, I will give them a call, I wouldn't mind stocking them.
Old 04-16-2014, 01:54 PM   #17
fnkngrv
fnkngrv's Avatar
Garm,
Lemme know if you would like me to send you the spec sheet I received from Web on Art's cams.
Old 04-16-2014, 02:45 PM   #18
frambach
Drives: 2008 Liftback
This can be deleted. Sorry to clutter.
frambach is offline   Reply With Quote
fog light options charleschia1986 Cosmetic Modifications (Exterior/Interior) 3 11-13-2009 04:00 PM
TRD Options S1L3N7 D3A7H New YARIS Purchase Forum 26 01-20-2009 01:52 PM
OEM Aerodynamic options (to 'S' or not to 'S') invol Fuel Economy Forum 6 12-02-2008 10:29 PM
Which options are dealer installed? grampi New YARIS Purchase Forum 4 07-30-2007 01:23 AM
