Old 07-13-2014, 12:14 PM   #1
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Good job :) can u take side shot of car ...as for ur exhaust I would definitely fix that cos over time may damage something ,can u maybe use different length rubber mounts or bend the hangers just a little to get clearance.
Old 07-13-2014, 12:16 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Now drive it for a week and then get toe done cos ur wheels will be toed out with drop.
Old 07-13-2014, 12:21 PM   #3
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Also add a rear TRD sway bar makes for a huge difference on Yaris ...anyhow good job now go have fun enjoy ur ride.
Old 07-13-2014, 12:23 PM   #4
vaironl
vaironl's Avatar
Drives: 2010 Yaris 3 door, manual tran
Advice Installing Shocks/Struts and Lowering Springs
I have a trd sway bar lol. Here are the pictures of what it's touching should I add a nut net to the rubber hanger?
vaironl is offline   Reply With Quote
Old 07-13-2014, 01:06 PM   #5
vaironl
vaironl's Avatar
Doing the zip ties as a temporary fix. I feel as if the vibration will just bend it back I don't even have an idea of how to bend it?
Old 07-13-2014, 12:26 PM   #6
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
I think if u remove it and bend the hanger on the exhaust a bit just by looking at the pic would be the easiest ..muffler shop could heat it up and do it proper unless u can give it a try.
Old 07-14-2014, 04:51 AM   #7
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
I took both rubber hangers off. After relocating the axle beam, my DC Sport kept rattling against the axle beam metal tab protrusion. This might fix your problem, instead of the hangers i used Hose clamps with a small piece of rubber to keep any rattling from happening.
Check out my Build thread:
AG Lowering Springs + XA Raceland Rear Springs! So-Cal!! braytonia Items for Sale by private party 6 09-21-2014 10:30 AM
what to look out for when installing lowering springs songa Performance Modifications 34 09-15-2012 03:29 AM
Which lowering springs with stock shocks/struts Palmer812 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 03-08-2010 11:00 PM
Is it practical to install stiffer shocks without also installing lowering springs? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 01-18-2007 01:23 PM
