Old 08-22-2014, 11:22 PM   #1
SpeedyYaris
SpeedyYaris's Avatar
Drives: 2009 3door 5-speed Manual
Could you link me the one you got? Thanks :)
SpeedyYaris is offline   Reply With Quote
Old 08-22-2014, 11:23 PM   #2
428CobraJet
Drives: '09 Yaris 3dr, 13 F150rcsb 5.0
Imho...a rear sway bar decreases a car's directional stability (making it more nimble). This one seems to increase the stability. Turn in seems unaffected (well...it leans less...i guess you could say its better).
You are what you drive.
428CobraJet is offline   Reply With Quote
Old 08-22-2014, 11:34 PM   #3
428CobraJet
http://stores.revolutionparts.com/to...lineparts.com/
They were the cheapest i found in April. Liked it so well i bought one for my brother's 09 3dr as well.
http://www.toyotaonlineparts.com/oe-toyota/ptr1152071
Do a search on this forum. There is much info on how big an improvement there is. Great thing about this forum! And looks like the new SE is coming with it (if i read correctly).
Old 08-23-2014, 09:36 AM   #4
aspro
I've driven my yaris flat out (182 km/h) many times for quite some time and she ran smooth and sturdy every time I've done it. I also usually have the car on the highway between 130-140 km/h and it seems as if the yaris prefers to run at that speed. I also beat her up at the track ringing the motor out at the top of the power band for hours and it just keeps going. The car actually runs a lot smoother after a day at the track.
For reference, I do really maintain the motor. Always checking oil levels and Always synthetic with OEM Toyota filter and always change it at 5000km's. A bit overkill but I'd rather spend a little money now than a lot of money later on.
aspro is offline   Reply With Quote
Old 08-23-2014, 12:16 PM   #5
bronsin
bronsin's Avatar
Originally Posted by SpeedyYaris View Post
Hello I have a 2009 yaris 1.5 5speed manual.. I travel a lot between Phoenix and San Diego and I usually drive about 85-90 mph.. I notice the engine is roudy at this speed.. is it ok for the yaris to travel at these speeds or does it stress the engine?
Thanks in Advance!
Not a problem. I rode my Honda ST1100 motorcycle for 109,000 miles at those speeds and higher on cross country trips and the rpms were like 5000. The motorcycle has over 200,000 miles on it now under the current owner.
Engine block has never been touched.
At those temperatures and speeds I would NOT be running 0w-20 oil in it stick with the 5w-30. Or 10w-30. Your oil pressure will thank you!
Old 08-23-2014, 06:17 PM   #6
Kar98
Drives: 2011 Scion tC
Man... I must be getting old. At 92 mph is where I chicken out because then the car becomes too unstable and bounce for my taste. Other cars of similar size, I had no problem going 100, 110. (VW Scirocco and Rabbit GTI)
Old 08-23-2014, 11:33 PM   #7
nookandcrannycar
I haven't hit 92 in my 2007. My 2014 feels so taut, if it was legal, I'd take it to the maximum speed it could manage. I've taken a Scirocco to the equivalent of 100 and a Rabbit GTI to close to the equivalent of 110 MPH, and another car to the equivalent of 140+ MPH. Not saying which country hosted my driving at those speeds . I share your sentiment above re not driving at 'top speed', but I think it is because I look at life differently, not re a lack of nerve, etc.
P.S. - differently meaning different than I used to (not in relation to anyone else)
Old 08-24-2014, 02:15 PM   #8
KorJax
Drives: None
I think it should be fine.
Assuming cars are like video cards, you can run them at near max load (in video card terms: load = temperature) because they are designed to not fall apart until beyond that point. But you just might not get the most efficient results (bad MPG's) if you do it and you might limit the lifespan if your other factors aren't up to par - i.e. if you have problems with cooling, oil, etc it would be extra bad if done at those speeds.
KorJax is offline   Reply With Quote
Old 08-24-2014, 02:43 PM   #9
Kal-El
Kal-El's Avatar
Not a problem. This motor is bullet proof.
When it comes to high speeds in the Yaris, the more important thing is to have a wheel and tire upgrade from the puny stock setup. The narrow stock rubber can be a bit unsettling. Wider, lower profile tires make a huge handling difference.
Old 08-24-2014, 09:04 PM   #10
nookandcrannycar
Old 10-03-2014, 04:28 AM   #11
Jlively
Mr J.
Drives: 2009 yaris 5 dr HB
Send a message via AIM to Jlively
My Dodge truck has a true bullet proof motor ha ha.
I have an 09 a/t 5 dr hb and I do prolly 65-70 mph daily np and not really any engine noise, at least not enough to bother me. Ive had it up to 85 on our highway which is risky being our speed limit is 60 most places lol. But even around 85 I didnt experience any major engine noise. Maybe its bc I am used to my carbed 318 dual exhaust at 60-70 mph which is rather loud lol.
Jlively is offline   Reply With Quote
Old 08-24-2014, 09:06 PM   #12
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
well, not totally bulletproof...lol
Old 08-24-2014, 09:14 PM   #13
nookandcrannycar
Not when it comes to racing or other like pursuits, but you know what he meant .
Old 09-01-2014, 04:30 PM   #14
SpeedyYaris
This weekend i did make the trip and no problems Lol i just worry to much is all i guess... I did get it to 115 tho It felt like it could go faster but I let off.. Now makes me wonder what its top speed really is... The funny thing is it felt stable at 115... Or i was just too tense to think about it and was just trying to focus on the road !
I Noticed one problem though... I hit an area with high crosswinds and lets just say i was miserable for about an hour of the drive lol
Old 09-01-2014, 05:59 PM   #15
aspro
Mine topped out at 182 km/h
TRD sway bar, h&r coilovers, tanabe strut tower bar, konig feather, bfg sport comp 2, MI intake manifold, aem cai, dc header, trd catback, MI crank pulley, trd short shift kit, phillips hid kit, morimoto led fogs, parrot navi indash, alpine 6.5 speakers, alpine amp, alpine reverse camera, led interior lights, thule roof racks, netz badges...
Old 09-01-2014, 09:15 PM   #16
nookandcrannycar
https://autos.yahoo.com/news/speedie...231406153.html
Old 09-01-2014, 09:18 PM   #17
billyadm1706
Drives: Toyota Yaris Hatch '11 5-door
are you sure it's your engine sound? it could be your tire's sound..
as long as your engine does not produce rattling sound, you're good to go
billyadm1706 is offline   Reply With Quote
Old 09-01-2014, 09:52 PM   #18
fnkngrv
fnkngrv's Avatar
ecu limits the car to 118. at that point you will hit a fuel cutoff which leans the afr out to 18. This is not something that should be played around with as it will cause premature wear on the engine. as for top speed I know that I haven't maxed out the c50 trans yet and I hit 154.5mph officially in a mile and a half. I have hit mid 160s on the dyno. Still making adjustments and would really live to see what the c50 maxes out at before a rebuild. the car at least with my suspension setup feels fine at 150-155.
high speed, highway, toyota yaris
Voltage regulator and Amperage question... cr.chango DIY / Maintenance / Service 13 11-24-2009 12:59 PM
ctrl-alt-delete question & free anti-virus question Shroomster Off-topic / Other Cars / Everything else Discussions 18 09-08-2009 03:57 AM
Retrofit Question ChinoCharles Cosmetic Modifications (Exterior/Interior) 19 05-13-2009 06:20 PM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
catalytic converter question SamDaYarisMan Performance Modifications 14 09-08-2006 10:18 AM
