#19 |
![]() Drives: 2016 Yaris SE Join Date: May 2016
Can you guys post some photos of it installed? Don't really like looking at the stock photos I find online.
#20 | |
![]() ![]() ![]() ![]() ![]() Drives: '15 Yaris SE 5MT Join Date: Jun 2014
Plus, with my luck, my SE should have had those dampeners installed, but didn't due to some factory-assembly oversight. I won't know until someone else here with a 2015/2016 SE crawls up under their car and takes a look to confirm.
#21 | |
Here are some pics taken from another thread on YarisWorld (from a 2012 Yaris), that sort of illustrates what I just said above. The 2015/2016 really isn't any different underneath there as the 2012-2014, or the 2007-2011 for that matter. ![]()
#22 |
I can confirm that my 2016 SE doesn't have the dynamic dampers. Thanks for the photos. I will be ordering one later today. Would be be possible to get a photo from the back showing some of the rear bumper? I don't want too much of the bar exposed. It'll look weird seeing a red bar on a white car. I'm just trying to get an idea of how much would be seen from the views of a car behind me.
#23 |
![]() ![]() ![]() ![]() ![]() Drives: 2014 Yaris SE Join Date: Apr 2014
On my 2014 it is pretty much invisible from behind.
#24 |
Yep, the only part of the sway bar you can see is the rounded end-piece near where it is bolted onto the car - even when you are bending/squatting and trying to see it. You don't even really see the end-pieces if the sun isn't shining directly onto them. That bright red can really catch the sun though.
![]() I really noticed the handling/performance difference with it on the car today during my commute. The car stays flat as a pancake on spirited turns or taking those curvy "40 mph speed limit" highway on/off ramps at higher speeds. I also didn't feel the wind pressure buffet the car like it used to when big-rigs passed right next to me at high speeds on the highway. It really is the best bang-for-the buck stability mod that you can make to a small, featherweight car like this. |
#25 |
Those are the wrong size bolts. The thread pitch is wrong. If you want to keep the dampers you need M10-1.25X30mm bolts. In US I purchased from Fastenal, I 'm sure they're available somewhere in Europe but I don't know where.
#26 |
Yep, the bolts supplied with the TRD sway bar won't work if you plan to keep the dampers on your 2012-2014 3rd Gen.
#27 | |
![]() ![]() ![]() Drives: 2012 Grey Toyota Yaris SE Join Date: Dec 2011
https://www.fastenal.com/products/details/11116351
Upgrades: AFE SRI. Tanabe Touring Medalion Axleback exhaust. Micro Image OEM Sized Lightweight Pulley. DC Sports header. |
#28 | |
#29 |
Oh nice nice! I'll go with the yellow zinc ones then thank you!!!
#30 |
![]() ![]() Drives: 09 3dr (sold), 12 SE 5spd : ) Join Date: May 2009
I am so glad that I came across this post. I sold my 2009 Yaris about 3 years ago which I installed the TRD rear sway bar on. I am buying a 2012 Yaris SE this weekend and I plan on getting another TRD sway bar ASAP. This is the number one mod that everyone should do to the Yaris.
Now I know that I will need to buy new longer bolts to make the TRD sway bar fit properly. Did you remove anything from the car, or did buying the longer bolts allow you to keep the dampers in place? I am going to have to take a look at these dampers when I get my car. I am really curious what purpose they serve and why they took them off after 2014.
Its all about the MPG's !! |
#31 | |
I have a mini DIY posted on the previous page that should answer any other questions. |
#32 |
![]() ![]() ![]() Drives: Charcoal 2012 Yaris SE 5 Speed Join Date: May 2016
Does anyone know if this bump stop would be reused with a set of tanabe sustec coil overs?
#33 | |
Drives: 07 Yaris Sedan Aero Join Date: Oct 2006
Sent from my SM-G930W8 using Tapatalk |
#34 |
I can't remember if there are bump stops with them. I'll have to look.
I just ordered a white line 22mm rear sway bar for my 2012. Does this issue still apply in my situation? |
#35 |
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
Just to be clear: These are not bump stops. They are just vibration dampeners to deal with NVH. Basically some chassis engineer found that in that area of the vehicle there was a vibration that may cause excess noise to the driver. So they bolt a dampener in place because it's cheaper than making new axle assemblies. Chances are you can remove the dampener and never notice any noise difference.
#36 | |
| TRD rear sway bar? | Lewis | DIY / Maintenance / Service | 26 | 09-10-2013 02:10 PM |
| FS: TRD Rear Sway Bar NY/CT/NJ | enviri | Items for Sale by private party | 8 | 06-13-2013 10:46 PM |
| Any interest in a used TRD rear sway bar? | ricktoyota73 | Items for Sale by private party | 10 | 09-06-2012 10:08 PM |
| Which rear sway bar? | IsLNdbOi | Performance Modifications | 46 | 11-05-2009 06:07 AM |
| TRD rear sway bar | cali yaris | Items for Sale by private party | 19 | 05-23-2009 05:23 PM |
