#1 |
It is interesting though that some pumps will say that they measure volume not energy content, which can change with temperature of the fuel (density)
#3 | |
Only Happy When it Rains
All pumps measure volume. You cannot measure energy content outside of a lab.
Colin Chapman disciple |
#4 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2('14+'07)MT 3d ,wHandCrWndws! Join Date: May 2009
#5 |
![]() Drives: Silver Yaris Sedan (4A) Join Date: Jul 2007
the Mythbusters show did a study on this exact topic, The results showed that (at least for their particular test car, not a Yaris) that it depends on the speed you are driving at, at highway speeds it is acturally better to turn on AC then opening the windows as the drag does affect gas milage, while in local traffic opening the windows gives better gas milage.
#6 | |
#7 |
![]() ![]() Drives: '00 Echo Join Date: Mar 2014
Windows open do contribute to drag...you're breaking the smoother wid line and instead forcing it into a dead end in the car. Lower speeds? No big deal. Higher speeds it starts to suck more and more. And ac is always a huge killer on these little engines. It sucks about 5mpg or so, consistently, on the highway, and more like 8-10mpg in town. Bleagh.
#8 | |
Your point is somewhat correct on the open windows, but not on the ac. We are in the era of more and more electronics and manufacturers are doing everything they can to get better gas mileage numbers, including electric ac, which does not hurt gas mileage as much or at all depending on the car.
#9 |
I suppose that's true. I am using numbers observed from my Echo, rather elderly now I suppose. I barely use ac. Larger vehicles are of course less affected by ac use, as the power needed to drive the compressor is proportionately much less.
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
| New CAFE rules nearly double fuel economy by 2025 | digitalrain | Fuel Economy Forum | 27 | 02-24-2012 11:49 PM |
| 2012 Camry | Kal-El | Off-topic / Other Cars / Everything else Discussions | 26 | 10-02-2011 09:20 PM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
| Forced Induction and Fuel Economy | ellenbetty | Fuel Economy Forum | 11 | 08-13-2009 01:12 AM |
