Old 10-10-2014, 01:13 AM   #19
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
Im also on 8k all around, full soft on the dampening, sure its not comfy in bumpy roads/pot holes, but slapping the car left and right is tight on rails.
Check out my Build thread:
Old 10-10-2014, 01:14 AM   #20
nobodywise
nobodywise's Avatar
Drives: Yaris sedan
Well, anyone have any experience with BC?
Which are front: 5k & back 3k
http://www.andysautosport.com/produc...__C-16-BR.html
nobodywise is offline   Reply With Quote
Old 10-10-2014, 01:20 AM   #21
nobodywise
nobodywise's Avatar
Drives: Yaris sedan
If you want flush, lots of low, and the ability to have passengers.....you will need different spring rates. The springs either set comes with will be too soft, and you will likely bottom out lots. Everyone's said no to megan, but I like mine. I'm running 8k springs all around and while the ride is a little stiff, the dampenimg can adjust that. I'm less than 3 inches from the ground, too. Just my 2 cents :D
So if I order the megans I'll just have to order special springs I assume
Keep in mind, I have a sedan (don't know if that makes a difference at all)
I want something that can take me thru bumpy roads and potholes without me having to call 1-800-chiro-practor
Also, what's the point of getting higher spring rates if you're just gonna put the dampening on the softest? Wouldn't that be the same as.. let's say 6k with the dampening in the middle?
I love the back of my car, the front... not so much
Old 10-10-2014, 01:22 AM   #22
nobodywise
nobodywise's Avatar
Drives: Yaris sedan
To add ^
I'm not worried about my own comfort. I'm worried about the comfort of everyone else who gets in my car.
If it was just me, living on my own, I would have got Megan 8k all around and slammed my car
Old 10-10-2014, 09:48 PM   #23
nobodywise
nobodywise's Avatar
Drives: Yaris sedan
I wish I knew my current spring rate, it would make everything a whole lot easier
Old 10-11-2014, 08:31 AM   #24
1.70k front / 2.14k rear
Old 10-11-2014, 09:10 AM   #25
nobodywise
nobodywise's Avatar
Drives: Yaris sedan
No, I'm on some cheapo ebay springs called "lotek" and the sell only said that they are 'about' 20% stiffer than stock
Old 10-11-2014, 08:02 PM   #26
Ben_
Drives: 2010 Yaris Hatch
I've only heard of people needing/using/wanting adjustable socks for track use. For everything else it's a bit of a nuisance
Ben_ is offline   Reply With Quote
Coilover question... Deshi Basara DIY / Maintenance / Service 7 05-24-2013 03:43 PM
General PIAA foglight question Yaristeve Cosmetic Modifications (Exterior/Interior) 2 07-03-2012 03:10 AM
ctrl-alt-delete question & free anti-virus question Shroomster Off-topic / Other Cars / Everything else Discussions 18 09-08-2009 03:57 AM
So question here abt hatchs in general Jem_hadar General Yaris / Vitz Discussion 12 01-06-2009 03:06 AM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
