Old 10-07-2014, 03:46 PM   #1
nobodywise
nobodywise's Avatar
Drives: Yaris sedan
A general coilover question
Hey everyone, hoping you can help
I need to order some coilovers asap so let me give you a brief
-I plan to only street drive my car (its a daily driver), no track whatsoever.
-I live where the roads are a mixture of smooth and bumpy
-The fastest I probably go is 40-45mph
-I usually have people in the car (so I want to go completely flush and when people are in the car it doesnt drop too much)
-I want to have it flush with my tires (no wheel gap) and go lower in the future (Wheel setup: 16x7 40et wrapped in 195/45s)
I read through the threads and Its between:
Megan Racing Coilovers (spring rates: 6k front/3k rear) 32 levels of damper adjustment
TEIN Street Basis coilovers (4k front / 3.1k rear)
No damping adjustment
The only differences between the two are the front spring rates and the ability to adjust damper I guess.
What i have read so far is that the megans are too stiff and people dont like it
but on the other hand, the Teins dont drop as low.
I was leaning toward the megans but are the 6k on the megans really that unbearable (I don't want my passengers complaining)
I want whichever one has a better balance between comfort and the lowering capability.
Can you help me decide?
I love the back of my car, the front... not so much
nobodywise is offline   Reply With Quote
Old 10-07-2014, 04:02 PM   #2
This
Doesn't go with this
I say go with Teins as there is a lot more experience with those on here vs the Megans.
Old 10-07-2014, 05:08 PM   #3
sheekeebut
Minimalist
Drives: 07 silver sedan
Tein Basis installed on mine. Check my thread, and PM me if you've got questions. But for comfort, low ride, and no rubbing.. I say you pick two.
sheekeebut is offline   Reply With Quote
Old 10-07-2014, 05:30 PM   #4
nobodywise
nobodywise's Avatar
Drives: Yaris sedan
Sorry @WeeYari forget the "when people are in the car it doesnt drop too much" part
Wanted something that's stiffer yet still comfortable
But wanted to know if the 6k on the megans are really that bad because I thought you could counter that with damper
Old 10-07-2014, 06:59 PM   #5
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
You can't counter anything, it is just one adjustment that changes both things.
Comfort does not go with coilovers, if you want comfort get Tokico reds and springs.
Colin Chapman disciple
Old 10-07-2014, 07:19 PM   #6
nobodywise
nobodywise's Avatar
Drives: Yaris sedan
Okay, what if I said more comfortable to ride on lowered since the Teins dont have dampening
Old 10-07-2014, 07:19 PM   #7
nobodywise
nobodywise's Avatar
Drives: Yaris sedan
Adjustable*** ^
Old 10-07-2014, 09:22 PM   #8
aspro
Why don't you consider the h&r coil over kit. Really well built, its only height adjustable, though. It doesn't slam but it goes pretty damn low. The pic in my Sig is with my setting of the h&r kit and it had quite abit more space to go lower but I was rubbing at that point in corners. My rims are 15x6.5's with 38 offset and 195/55/r15 tires. Same diameter as stock but slightly wider (I believe an inch wider)
The h&r kit rides really comfy (for a coil over). It actually rides exactly like my 2012 wrx sti OEM suspension. But it handles really well, I mean completely changed the driving charecter of the car for the better.
Here's a link to my install.
http://www.yarisworld.com/forums/sho...h%26r+coilover
TRD sway bar, h&r coilovers, tanabe strut tower bar, konig feather, bfg sport comp 2, MI intake manifold, aem cai, dc header, trd catback, MI crank pulley, trd short shift kit, phillips hid kit, morimoto led fogs, parrot navi indash, alpine 6.5 speakers, alpine amp, alpine reverse camera, led interior lights, thule roof racks, netz badges...
aspro is offline   Reply With Quote
Old 10-07-2014, 09:56 PM   #9
nobodywise
nobodywise's Avatar
Drives: Yaris sedan
The price unfortunately.
I want the exact look you have: No gap
Just barely tucking is my goal
I think it's worth saying that I'm rocking a sedan
Old 10-07-2014, 10:11 PM   #10
sheekeebut
Minimalist
Definitely heard that
Old 10-08-2014, 03:00 PM   #11
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
FYI, I just returned your PM.
Cliff notes:
Megans = too stiff for me
Megan quality = poor (the paint on my coils started to flake off; springs started to rust)
Megan customer service was very poor when I dealt with them in 2007.
Currently I'm on Tein S-Techs and Tokico HPs and have been very happy with the setup. I don't need stuff; I don't need adjustable. I need functional and stylish, and my setup fits the bill.
Old 10-09-2014, 09:15 PM   #12
why?
why?'s Avatar
Drives: Yaris LB
Cliff notes:
And unless you absolutely need the adjustability this is the way to go. With my Megans to adjust the fronts I would need to take 3 or 4 pieces off. I could do it in maybe 30 minutes, but then I would need to put it back on. Not worth it.
Old 10-09-2014, 09:25 PM   #13
nobodywise
nobodywise's Avatar
Drives: Yaris sedan
Can you explain to my why I would need the adjustability? I just want to tuck a tiny bit. I'm leaning more towards the teins now
Sent from my iPod touch using Tapatalk
Old 10-09-2014, 09:30 PM   #14
That's the thing. You don't need it.
Old 10-09-2014, 09:33 PM   #15
nobodywise
nobodywise's Avatar
Drives: Yaris sedan
The Teins should be okay to get rid of wheel gap then correct? I just don't wanna make the mistake and regret it
Old 10-09-2014, 09:37 PM   #16
Are you talking Tein S-Tech springs, or the Street Basis coilovers? With a drop of almost 2", the S-Techs will completely eliminate the gap. All with the simplicity of just a spring.
Old 10-09-2014, 09:41 PM   #17
nobodywise
nobodywise's Avatar
Drives: Yaris sedan
Old 10-10-2014, 12:45 AM   #18
mr_miles
Drives: 2013 Yaris
If you want flush, lots of low, and the ability to have passengers.....you will need different spring rates. The springs either set comes with will be too soft, and you will likely bottom out lots. Everyone's said no to megan, but I like mine. I'm running 8k springs all around and while the ride is a little stiff, the dampenimg can adjust that. I'm less than 3 inches from the ground, too. Just my 2 cents :D
Coilover question... Deshi Basara DIY / Maintenance / Service 7 05-24-2013 03:43 PM
General PIAA foglight question Yaristeve Cosmetic Modifications (Exterior/Interior) 2 07-03-2012 03:10 AM
ctrl-alt-delete question & free anti-virus question Shroomster Off-topic / Other Cars / Everything else Discussions 18 09-08-2009 03:57 AM
So question here abt hatchs in general Jem_hadar General Yaris / Vitz Discussion 12 01-06-2009 03:06 AM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
