Old 11-23-2014, 08:32 PM   #1
Eduardo_mty
my english is too short....pictures "talk" more
tail light in curt wire work
stop light in curt wire work
Eduardo_mty is offline   Reply With Quote
Old 11-23-2014, 08:44 PM   #2
Eduardo_mty
tail and stop light pict.
Old 11-23-2014, 08:52 PM   #3
OK. From the pictures of the right side connector I can't tell which blue lines up with which wire on the top of the connector, but the darker blue (called sky blue) wire is the right turn signal wire.
Old 11-23-2014, 08:58 PM   #4
Eduardo_mty
ok, i do you mean, that i will change the tap to the dark blue wire
Old 11-23-2014, 09:08 PM   #5
Actually I was remembering the blue colors wrong. The lighter blue is "sky blue". So, you want to connect to that wire or to the wire that it connects to on the other side of the connector.
Old 11-23-2014, 09:13 PM   #6
Eduardo_mty
CTScott, please see this pict...
Old 11-23-2014, 09:17 PM   #7
OK. So you are on the correct wire. Make sure your tap splice is actually making contact through the insulation.
Old 11-23-2014, 09:27 PM   #8
Eduardo_mty
tap splice is making contact, i did a "test"connect direct the green wire from wire connector, to a and do not work
Old 11-23-2014, 09:30 PM   #9
Try switching the left and right input wires on the curt and see if the problem stays on the right. If it does then the curt unit is the problem.
Old 11-23-2014, 09:32 PM   #10
Eduardo_mty
Thank you, i will do tomorrow, if not Work... I will need some help to Write to seller...
Old 11-23-2014, 09:55 PM   #11
Eduardo_mty
Ctscott i did that you said.. Change the left to right and the curt unit is the problem..
I bought from Amazon And they ship to friend house.
I need help to ask a New one...
With the correct words
Old 11-23-2014, 10:00 PM   #12
"I recently purchased a Curt trailer light converter from you. After installing the unit I found that the right side turn signal does not work. I switched the right and left turn signal wires to the Curt converter and the problem remained on the right side, so the unit is definitely bad."
Old 11-23-2014, 10:02 PM   #13
Eduardo_mty
Thank you... Do you think they want the damage unit... Becouse my friend will go in two weeks to USA
Old 11-23-2014, 10:07 PM   #14
Yes. They will probably want the bad one back.
Old 11-23-2014, 10:11 PM   #15
Eduardo_mty
is good or bad idea if "we" add this words
"I send this to my cousing in México And he back to USA in two weeks,"
Old 11-23-2014, 10:24 PM   #16
I would leave that off.
Old 11-23-2014, 10:46 PM   #17
Eduardo_mty
May i buy a universal wire connector or i need the specific wire connector
If its universal i will try to find here in México
Old 11-23-2014, 10:51 PM   #18
Any universal one will work.
Help me install my Infinity Basslink! wsladaritz In Car Entertainment + Electronics (audio / video / alarm) 17 10-21-2008 12:15 PM
Help me install a converter to HU wsladaritz DIY / Maintenance / Service 8 09-07-2007 06:54 PM
Harman Kardon Drive + Play for IPOD sroberts In Car Entertainment + Electronics (audio / video / alarm) 5 07-01-2006 01:05 PM
