Old 12-04-2014, 04:16 PM   #19
harda toenail
Drives: Want a yaris
Ive got this noise. Did you have to drop the engine to get the pump out?
harda toenail is offline   Reply With Quote
Old 12-05-2014, 08:42 AM   #20
vrizrak
Drives: 2007 Yaris Sedan
Yes. Thanks to Kou on his DYI. http://www.yarisworld.com/forums/showthread.php?t=12727
First I've put car on jack stands. There is 2 bolts and 1 nut. The nut is right under engine mount. You will need a long extender with 14mm socket. So remove nut first. Then place your floor jack and pump it until it hold engine a little bit. Then remove 2 bolts from the top. Also 14mm.
vrizrak is offline   Reply With Quote
Old 12-05-2014, 09:49 PM   #21
You can actually replace the water pump without removing the engine mount. Remove the screw that mounts the AC pipe holder and slide the holder towards the front of the car. Once you do that you have room to remove the pulley and then the pump itself.
Old 12-06-2014, 07:21 PM   #22
harda toenail
Thank you scott, I'll try to go that route. I loosened my belt and the noise went away but I know the bearing is probably damaged. If a warm day comes around I'll swap it out.
Old 12-09-2024, 08:34 PM   #23
Guyon
Drives: 2009 Toyota Yaris 5MT
Drat, I missed the 10th anniversary of this thread's last post.
At any rate, to any fellow internet searchers trying to identify that sound, our 2009 Yaris with a 1NZ-FE made this exact sound. It was the water pump. I replaced it and the sound completely went away.
Guyon is offline   Reply With Quote
Weird Noise, unsure rpicard@demand-its.com DIY / Maintenance / Service 2 02-12-2013 03:52 PM
Weird Spark Noise Behind Steerinf Column! ChitownY@Ris DIY / Maintenance / Service 8 07-28-2011 11:18 PM
The weird, old and new. Brakes, Sqeaking, Suspension noise Lafiro DIY / Maintenance / Service 2 10-31-2010 10:20 PM
weird rattle-grind noise when braking. krolos General Yaris / Vitz Discussion 4 08-10-2010 07:07 PM
07 yaris weird engine noise mr07yaris General Yaris / Vitz Discussion 22 07-21-2010 08:33 AM
