Old 06-19-2015, 12:15 PM   #19
justjesus
justjesus's Avatar
Drives: 2008 Liftback
Originally Posted by CoryM View Post
The UV protectant is a MUST no matter what system you use or it will quickly end up hazed again.
What have you done for UV protection?
The Meguiar's Clarity kit, per one vendor, "Meguiar’s proprietary coating prevents re-oxidation for up to a year!"
Old 06-20-2015, 12:02 AM   #20
CoryM
Drives: 2009 5-door, 5-speed
I've just been using the Meguiar's "Headlight Protectant" which comes in the cleaning kit. That being said, I think we had a car come in today that I did a few months ago and it was already looking pretty bad. I will find out for sure if it was the car I am thinking of and post. If it only lasts that long, I think I will stop doing it (I don't want to charge customers for a temporary fix).
Old 06-21-2015, 12:50 PM   #21
CoryM
So yes, unfortunately the car was the one I was thinking of. The headlamps were fogged very badly, and now 2mo after being polished and coming up decent, are looking bad again. Maybe 1/2 of what they were before. The polishing is easy to get good results, the UV protection... not so much. I did a friends car that is now garage kept, and it looks good after several months. The boss is going to look into what the pro detailers use and we will give that a try next.
Old 06-23-2015, 01:52 PM   #22
justjesus
justjesus's Avatar
Keep us posted!
Thanks
Old 06-23-2015, 02:33 PM   #23
I used bug spray on my Saturn and it worked pretty good. The Deet is what clears it up
Old 06-24-2015, 03:22 PM   #24
hatchbackkid82
Drives: .
Well, well, well, look who it is.
Old 06-25-2015, 02:35 PM   #25
Herbie!! lol
Old 03-12-2017, 09:58 AM   #26
elladka
Drives: Vitz 2000
i used paint thinner on mine, worked miraculously. But be careful as thinner eats plastic which the lenses are. By eats i mean when i did mines it left a few lines like scratches, then i put clear coat and now they are perfect.
elladka is offline   Reply With Quote
Old 06-12-2017, 05:23 PM   #27
RedRide
RedRide's Avatar
For those who use" PLASTX" (as I also do) don't forget to also give your tail lights a little love with it.
Grime and haze might not show up as much as with the clear headlights but, it's still there.
Old 06-22-2017, 12:16 AM   #28
David C
Drives: White '07 3dr LB
Head lights getting hazed from abrasion?
I use NuFinish car wax and I get pretty decent results. Most car wax will do. I simply use a microfiber mit, rub a few minutes, maybe 3-5 times a year, when I happen to be waxing the car. Headlights are 11 years old. I also do the tail lights.
David C is offline   Reply With Quote
Old 05-19-2018, 04:48 PM   #29
beowulf
Drives: 2008 3dr hatch, 1.5L, 5-spd MT
I used this about 2 weeks ago on my Yaris. It has 2 grit levels of sandpaper to sand by hand and a polishing wheel to use with your drill. After sanding and polishing, there is a clear coating that is applied to provide protection "for up to 1 year".
It took less than an hour to do both lights. I was quite pleased with the results. Headlights were like new.
https://www.amazon.com/Meguiars-G298...estoration+kit
beowulf is offline   Reply With Quote
Old 05-19-2018, 06:17 PM   #30
Kalispel
Kalispel's Avatar
Drives: '15 Yaris SE 5MT
I had the 3M UV/Scratch protectant clear film installed on my Yaris headlights shortly after purchase almost 3 years ago, while having my windows tinted at same time. It has worked great for keeping my headlights looking brand new & crystal clear even with the super harsh sun, UV & grit/sand/dirt out here in Phoenix. Most cars around here have hazy looking headlight thanks to the elements, after only a few years. Putting that film on restored headlights would work equally as well for maintaining that restored/clear look without further effort.
Kalispel is offline   Reply With Quote
Old 05-20-2018, 09:18 AM   #31
dogsridewith
Drives: 2007 2-door hatchback
Headlight haze toyota yaris
Some of mine (on the likely original 2007 unit) looks like condensation, and whatever goes with that, on the inside of the lense?
(Headlight haze toyota yaris)
Old 05-20-2018, 09:58 PM   #32
MadMax
MadMax's Avatar
Regular maintenance will keep your headlights clear. Don't pay exorbitant rates to clear them up if they are fogged, some plastic cleaner and a little elbow grease will fix them right up. I do all our cars about once every three months...
Old 05-20-2018, 09:59 PM   #33
BennyLava
Drives: 1987 Silverado
Subscribed for when I do mine.
BennyLava is offline   Reply With Quote
Old 06-17-2018, 08:31 AM   #34
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
I refinished mine using 1500 grit wet sanding followed by compounding with my dual action polisher. They came out good and clear, but I can already see slight yellowing occuring despite applying acrylic sealant - Klasse High Gloss Sealant Glaze - the most durable sealant I'm aware of and it has UV protection.
Here is a link to my attempt at refinishing them (about 1/2 way down the page).
http://www.yarisworld.com/forums/sho...ht=renovations
I am going to be painting my car soon and may clear coat the lights when I spray the clear. I'm not fully decided as several years back I had the headlights of a wagon I had sanded and cleared at a body shop. A few years after I sold it, I saw it in a parking lot and the clear coat was blistering off in big chunks. Maybe it was rushed through with inadequate prep, but maybe not.
Yaris Halo Head Lights djgab101 Cosmetic Modifications (Exterior/Interior) 11 04-10-2011 09:29 PM
WTB: taillights and head lights. firemachine69 Willing to Buy by private party 3 11-16-2010 01:42 AM
Instrument Panel goes out if I turn on my lights ceceb DIY / Maintenance / Service 9 07-08-2010 05:56 PM
Solar powered High Bright LED lights replacing the fog lights alan1828 Canada 10 05-14-2010 12:34 AM
head lights KSIbucky DIY / Maintenance / Service 2 10-28-2006 12:22 AM
