#1 |
![]() ![]() ![]() Drives: toyota yaris Join Date: Jan 2007
Yaris Halo Head Lights
Hey guys i brought these head lights and got them installed they look awesome but i am having trouble adjusting the head lights up and down!
does anyone know how i can move the head lights down cause my lights are too high!
(^)-_-')
post a higher res picture.. of the back side
#3 |
![]() ![]() Drives: 2009 yaris 4dr hb Join Date: May 2010
is that for 09 yaris? can you tell me where you got them?
#4 |
there are adjustment screws at the back of projector...you need to seat the headlights w/o screwing them in, see where the beam hits a wall (at dusk) and then pull out the headlights to adjust them and reseat them.
#5 |
Thanks guys I finally got them working :)
They are for a 09 Yaris hatch I got them off eBay for 300 Aussie dollars they look great :)
#6 |
Now that I have got them working I am trying to make my halo lights with the three LEDs come on when I open the car with the remote! I tried hooking up the dome light to the halo lights and the three LEDs but it won't work I need to find another way to make it work
Does anyone of a circuit board or DIY or method to get this working i am running out of ideas
#7 |
Not quite a noob
Drives: e46 325 Join Date: Jul 2009
You need to hook up the dome light signal to a relay.. if you try tio just draw power fom the dome light it won'tbe enough I don't think. So you'd need a line from battery > relay > halos
#8 |
Thanks for ur response if I got power from the dome to the relay to the haloes u reckon it would work? I am gonna have to shop around and look for a relay I am sure eBay or the shops have some
#9 |
toyota
Drives: 2007 Yaris RS Blazed Join Date: Oct 2006
love those lights..
#10 |
Not quite a noob
Well it's just a hunch, because however little power LEDs draw when you're trying to light up THAT many lights from one source I don't think there's enough power. You can do a test like hooking up the LED's right to your battery and seeing if they light. And then hooking up only one set to the Dome circuit and seeing if they light.
#11 |
toyota
itll work i have 10 hi leds tapped on my turn signal with no issues. i believe u only need 1 watt to run it.
#12 |
U guys are legends I think it should work from the dome light i gonna draw power from their I am gonna have to get a relay tho to see if it would work :)
| 2006 Yaris Hatchback Replacing Stereo Head Unit help | lauren24 | In Car Entertainment + Electronics (audio / video / alarm) | 11 | 07-01-2010 11:13 PM |
| Fitting Front Fog Lights OEM - Yaris 2007 3dr | weller | Cosmetic Modifications (Exterior/Interior) | 1 | 12-17-2009 12:29 PM |
