Old 09-19-2016, 04:17 PM   #19
I use krown every spring once the salt is off the roads. I pat myself on the back every time i work on my car. I also have a can of the stuff I spray on all the bolts undert he car any time I am working in that area.
For cavity protection of the bolt, marine grease will keep the water off of it is you liberally apply it to the threads
Old 09-19-2016, 06:47 PM   #20
Originally Posted by tmontague View Post
NO idea if the new bolts are any better but I installed 2 new bolts 2 years ago (purchased form the dealer). I covered them in marine grease before installation and when I removed the last year to check them out they were still covered in grease and in great shape.
Due to this I will not be taking them out to inspect until every 2 years. I do oil spray my car every spring but that likely does not get to the area where the bolt threads into
The correct fix is to seal the seams, as per the TSB. I have done so on mine and have found no moisture at all in the bolt sleeves a year after doing so.
Here is the TSB again:
T-SB-0055-11 (Clunk Noise from Front Suspension).pdf
Old 09-19-2016, 07:27 PM   #21
bronsin
bronsin's Avatar
Can you ignore this issue if you live in a warm climate where roads aren't salted?
Old 09-19-2016, 07:43 PM   #22
Depends on how much rain you get.
Old 08-26-2019, 04:26 PM   #23
w5gfr
Drives: 2010 Yaris 2dr Hatchback
Clunk in front end
Maybe its too late to do anything at a Toyota shop BUT my 2010 2dr Hatchback has for several months now been making a noise as described. Since I live in central Texas and the car has never been near snow maybe it took longer to rear it's ugly manners. My question is does Toyota still have to comply with TSB-0055-11 at this late date ?
Thanks, Gordon
w5gfr is offline   Reply With Quote
control arm bolt, front suspension
Warning - Broken control arm bolt! CB900F2 DIY / Maintenance / Service 460 08-23-2020 05:54 PM
Front Lower Ball Joint Cotter Pin Replacment GrayYaris DIY / Maintenance / Service 5 04-25-2014 04:30 PM
HELP PLEASE (lower trans bolts) Iamdagerman General Yaris / Vitz Discussion 2 01-05-2014 10:16 PM
