#19 |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
Wow! So much awesome information here!
#20 |
Data doesn't lie
This is not applicable to those just swapping in the 2zr and keeping the Yaris C50. If you use the Yaris trans and mounts, the stock shift cables are fine.
#21 | |
![]() Drives: 11 GSE21, 86 AE86 Join Date: Apr 2016
Jeff
![]() 2011 Lexus IS350 6MT F-Sport with LSD 1986 Toyota Corolla GT-S Supercharged with TRD Stuff 2005 Toyota Yaris RS 5MT Short Track Car |
#22 |
Data doesn't lie
^ There is no need to use Xd mounts on a Yaris C50 trans in the first place. Let's not complicate this, people may get confused if this keeps getting mentioned...
If you have a: Yaris sedan trans- Use Yaris mounts, (AT driver trans mount). Yaris shift cables. Yaris axles Xd trans- Use Xd mounts. Xd Shift cables. Xd Axles
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 11-02-2016 at 10:42 PM. |
#23 |
If you use the 2ZR RH mounting bracketry though, I would think it would strain the mounts and/or the engine will not be mounted completely in line with the axle center. I don't think using the Yaris mounts on the Yaris C50 is the best idea.
If the 2ZR sits further forward in the engine bay (which it does), using the 1NZ C50 mounts will keep the transmission side (3 mounts) in the original location, but the RH mount on the timing cover will want to push the engine forward. Unless you modified that or used the 2ZR transmission mounts and cable, it seems best not to mix and match, but I don't know how off it would actually be. Jeff
#24 |
Data doesn't lie
OMG here we go....
#25 |
Data doesn't lie
They seem to have the same measurements
#26 |
![]() Drives: 08 yaris 1.8 dual vvti 5sp Join Date: Feb 2010
Yo have use all three XD mounts for the swap ,if you just try to use the one XD Rh mount for the engine it puts just the engine lower ,So your engine and transmission will sit crooked. The Xd mounts are longer by couple inches and the lower middle stabilizer mount is longer as well.The lower middle stabilizer mount pushes the bottom part of the engine forward so the oil filter assembly clears the sub frame.All this is so that the 2zr engine sits lower because its taller.(You have to use all three mounts in order for the engine to sit right).
You can stretch the yaris shift cables to fit but it will end up ripping out the studs that hold the cables to the body.Use Xd mounts and Xd cables with the yaris c50 transmission, trust me the other combinations won't work properly. Last edited by froger; 04-22-2016 at 01:04 AM. |
#27 |
Data doesn't lie
Can you guys provide pictures of your Xd mounts and how your engine is "sitting"....Ill provide pictures of mine with Yaris mounts to compare and we can put this discussion to rest
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 04-22-2016 at 01:54 AM. |
#28 |
LH in photo is 1NZ Yaris C50 mount, RH is 2ZR xD/Yaris C5x mount. You can visibly see the difference in the mounts. The transmission with the 2ZR sits lower/forward of where the 1NZ does.
![]() Is your swap a manual or an automatic? Jeff
#29 |
Toyota's diagrams also show the difference between the two mounts:
![]() Jeff
#30 |
I had already posted, but I think because I had linked to the images on another server it was moderating my posts? Not sure. I'll try uploading them to my server instead?
The RH mount is the Yaris 1NZ/C50 mount, the LH is the Yaris/xD 2ZR/C5x mount. You can see the difference in the mounts and how the 2ZR mount will move the transmission/engine primarily downward and a bit forward. The diagrams from Toyota show the same thing. Was your swap an auto or a manual? ![]() ![]() Jeff
#31 |
I posted some pictures and info, seems like my posts with pictures are being moderated, so they will need to be approved before they can be seen.
Jeff
#32 |
Do a bit of post whoring. I think the magic number is 10 posts, then you can put pictures up for public consumption.
#33 |
Interesting, well until the posts pop up, I'll just post a couple of links to be pics:
http://jeff.epicwelding.com/yaris_mounts1.jpg http://jeff.epicwelding.com/yaris_mounts2.jpg Jeff
#34 |
TOYOTA PART NUMBERS FOR TRANSMISSION CASE
2011 XD MIDDLE CASE 33111-12260 BELL HOUSING 31105-52060 END CAP CASE 33102-52020 2011 YARIS MIDDLE CASE 33111-12260 BELL HOUSING 31105-52060 END CAP CASE 33102-12021 END CAP PIECES ARE DIFFERENT BECAUSE THE XD TRANSMISSION MOUNT ALSO BOLTS TO THE SIDE OF THE TRANS MISSION. The photos bellow are of Xd and Yaris mounts. Xd on the left and Yaris on the right and at the very bottom is a zoom up of the offset of the mount , Xd first,Yaris second.The height difference minimal but the engine seemed to be pushed forward by a bit . Last edited by froger; 04-23-2016 at 08:47 PM. |
#35 |
Data doesn't lie
Thanks for posting these!
So what I'm seeing here is that the LH Xd mount is different because of a difference in the two transmission end cases right? I find it strange that the main trans case is not different when the Xd has a larger differential and axles....and the pitch-stop mount being a bit longer is only pivoting the bottom of the trans away from the subframe(probably for clearance of the larger axles). I still feel that you should use the mounts that go with your specific transmission, but it's your car...feel free to do what you want. My car has been through 6 races so far, much more stress than any daily driver, I'll let you guys know if something breaks. |
#36 |
Let's just agree both ways work , you thought my way didn't work and I thought your way didn't work,we both proved each other wrong.
I too will let everyone know if I have any problems with my car ,after all this information is for the engine swaps to come. Daily driven and raced since the summer 2014. |
| Yaris Motor Swap Thread *Read before posting swap threads* | Sabretooth | Performance Modifications | 219 | 06-10-2025 02:58 PM |
| My 2zrfe swap | brushforhire | Performance Modifications | 131 | 06-08-2016 09:43 PM |
| 1nzfe throttle body swap and fitment questions | EchoBob02 | Performance Modifications | 14 | 05-01-2014 08:02 AM |
| FS: COMPLETE 2ZZ SWAP!!!! (SOCAL) | AdeJong 03 | Items for Sale by private party | 4 | 04-05-2010 11:25 PM |
| Gauge Cluster Swap, other interior swap questions. | Adrenalingirl_K | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 04-09-2009 03:32 AM |
