#1 |
![]() Drives: 2007 silver yaris 3 door Join Date: Jun 2016
Yes Bro!!! We manage to wangle ourselves in everywhere!!
![]() But as far as I figured, the gearbox will be the same, but as you say, let's wait for someone who knows for sure to help out on that. Don't want to be going around talking ![]() I also thought about the 1.5 swap, but for real bro, I'm seriously into doing some massive turbo'ing on the car at some point, so in the long run the 1.5 won't cut it when it comes to power output. ![]() If I get the parts I sure will need the help!! so I'm all for the offered help! haha we'll make a jol of it like proud Suid Afrikaners!
2ZR swap. DO IT! Ask how!
Drives: 09 Meteoric Metallic HB Join Date: Feb 2011
This is why you can't use the Corolla/Matrix/Vibe engine bracket. All bolt holes for the engine block are aligned. Corolla P/N 12315-37030. The xD is 12315-37040.
#3 |
![]() Drives: Gas saver Join Date: Jul 2014
Hi,
Can I use the stock 2008 Yaris 5 speed manual transmission with the 2ZR-FE? My car is stock except for: Fidanza Flywheel (8.64 lbs) NST crank pulley McLeod Stage 1 clutch K&N OE filter box... ...That I installed this weekend. |
#4 |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
Yes you can.
#5 |
Yes, you can use the gearbox but you need the xD mounts (all six pieces) and the xD shift cables. The flywheel won't work (6-bolt on the Yaris vs 8-bolt on the xD) but the pressure plate and friction disc should be fine.
#6 |
Drives: 2005 Toyota Echo Join Date: Apr 2017
Will this be much different in an echo (04)? would the mounts be the same?
#7 | |
That said, don't let me stop you from doing more research and finding out!
#8 | |
![]() Drives: Echo 05 Join Date: Oct 2017
Echo and yaris are completly different the echo railsare way more narrow than the yarises.. Edit echo rails are parallele from the firewall, the yarises kinda gets in a U shape right after that, allows more room, a guy here swapped a 2zz in a 07 yaris but kept the OE 5 speed to avoid cutting the rails. |
#9 | |
Drives: 2015 Yaris LE 3door 1F7 Join Date: Feb 2017
Sent from my LG-H918 using Tapatalk |
#10 |
so will the highest ouput 2ZR fit in the yaris? aka the 148 HP one? cause like im about to ditch my 1nzfe as much as I love it, the greddy turbocharger on stock internals apparently makes 200Hp.
#11 |
![]() Drives: 2012 Yaris LE Join Date: Aug 2017
Is it compatible with 3rd gen Yaris too?
#12 |
![]() Drives: 2005 Yaris Join Date: Aug 2017
please post pics of the actual swap, putting the motor in, etc, excellent build thread, look forward to seeing how it actually looks with this motor inside it! Is the fuel pump enough not to starve this motor? Have you worn through axleshafts quicker?
#13 | |
As far as anyone can tell, yes. The chassis is the same on all of the USDM variants. We've had different results with the engine mounts on specific vehicles, so your mileage may vary. =) There's a few threads out here already. Check out brushforhire's, ArmstrongRacing's, TMontague's and my thread for details. It's really pretty straightforward, so not a lot of pictures have been taken during the physical installation. I absolutely recommend pulling the front clip to do the swap, as well as partially dropping the sub-frame. It looks like a stock motor in the engine bay as well, so not a lot of pictures of that either. =D |
#14 |
can we get pics tho .w.
#15 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
Of what? As stated there are plenty of archived pics on the forum regarding the swap
#16 |
we wanna see your finished product and stuff :D
#17 |
I'll see if I can find anything on my phone. Other than that just my signature pic is all I have
#18 |
Data doesn't lie
#3
| The 2zr-fe engine swap guide | ArmstrongRacing | Performance Modifications | 416 | 08-14-2023 03:14 PM |
| engine swap | yaris9876 | DIY / Maintenance / Service | 12 | 12-26-2013 10:27 PM |
| engine swap | djhuddy2442 | Performance Modifications | 6 | 04-11-2013 01:05 AM |
| Engine Swap | Nutzoids | Performance Modifications | 42 | 10-01-2007 06:20 PM |
| if i am thinking about an engine swap - from 1.3 to 1.5 - please help | ASHRAF | Performance Modifications | 15 | 01-03-2007 01:40 PM |
