Old 06-09-2016, 12:45 PM   #19
Rigaud
Drives: 2009 Yaris
Originally Posted by tarkus View Post
Seriously dude?
Sent from my LG-D801 using Tapatalk
Yup I agree with re-thinking!!!
2009 Toyota Yaris (Little toy)
2002 Audi A4 Avant Quattro 3.0L (Big boy toy)
1998 Subaru Legacy GT 2.5 (winter & DD)
Rigaud is offline   Reply With Quote
Old 06-09-2016, 01:45 PM   #20
Tinkerman
Drives: Yaris 5 speed
Seriously dude?
Yup, I'm serious. Most aftermarkets are junk and not trust worthy.
I am using NGK Iridium IX plugs.
I see, you picked the best plugs manufactures in the world.
Tinkerman is offline   Reply With Quote
Old 06-09-2016, 04:31 PM   #21
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
I always use the best replacement parts in my cars. 😀
Old 06-11-2016, 01:25 AM   #22
rabbito
rabbito's Avatar
when i got E85 chip tuned, i upgraded to NGK IX plugs..
the ecu tuner recommanded for higher heat range sparkplugs..😃😃😃
its actually up to you, if you dont have mods you can go for the stock NGK, Bosch plugs..if you have mods, you can go for better or higher heat range plugs..
Sent from my SM-J700F using Tapatalk
Cosmetic: Toyota red emblem
Old 06-12-2016, 12:49 AM   #23
tarkus
tarkus's Avatar
Just put the NGK IX plugs into my latest car today, a 2006 Yaris with 145k km (around 92k miles). Presumably it was still running on the original OEM factory plugs. Big change. The engine sounds smoother. It starts faster, and accelerates better. You can feel the difference immediately. 👍 😀
Old 06-12-2016, 08:28 AM   #24
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
now, people who use the single platinum thin wire NGK IX plug do understand they are short life ones, right?
jack black is offline   Reply With Quote
Old 06-12-2016, 08:29 AM   #25
rabbito
rabbito's Avatar
depends whats the purpose of the spark plugs... 😐
Old 06-12-2016, 08:22 PM   #26
tarkus
tarkus's Avatar
Very true, rabbito 👍. Anyhow, in my case these are NGK Iridium IX plugs. I stay away from copper or platinum plugs.
Old 06-23-2016, 10:28 PM   #27
fourbangingfun
fourbangingfun's Avatar
NGK iridium plugs installed at 130k miles. Pulled out Denso's. I assume they were from the factory. They were in great shape and didn't look like they even needed to be replaced. Replaced them anyways. At 170k now still running strong.
fourbangingfun is offline   Reply With Quote
Old 06-23-2016, 10:28 PM   #28
fourbangingfun
Old 06-23-2016, 10:28 PM   #29
fourbangingfun
New Spark Plugs, Engine Light Appear grvdggr Performance Modifications 6 09-21-2015 09:34 AM
Changed Spark Plugs MyzticZ3r0 DIY / Maintenance / Service 4 11-14-2014 12:58 AM
Laser plugs? - Awesome Altitude Off-topic / Other Cars / Everything else Discussions 1 04-24-2011 08:02 PM
article on spark plugs and the fit kngrsll Performance Modifications 4 08-01-2009 11:50 PM
Upgraded Spark Plugs For Boost whooppee777 Forced Induction Forum 9 02-14-2009 01:53 PM
