Old 04-28-2017, 07:43 PM   #19
SirDigby
Drives: 2007 yaris 3 door
sound system and leather adds weight=slows vehicle down.
spoiler adds drag=slows vehicle down
i have an injen intake. i think it was $130
injen flow tunes intake tube=speeds vehicle up (maybe .2 second faster 0-62)
k&n flow tune (???)
Old 04-28-2017, 11:49 PM   #20
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
Originally Posted by Yaris709 View Post
Will probably go with an intake soon and sometime in the future maybe a header will be installed. Probably wait for the manifold to leak and replace it with a header then
Install a 1zz (Corolla/ Matrix) throttle body to really open up the performance.
Sent from my phone. Please excuse any typpos.
Old 04-29-2017, 02:45 AM   #21
rabbito
rabbito's Avatar
not just opens up the performance...it really kick in :)
Sent from my SM-N920C using Tapatalk
Cosmetic: Toyota red emblem
Old 04-29-2017, 08:10 AM   #22
miiser
miiser's Avatar
Drives: yaris 2009
Cold air intake?
k&n flow tune (???)
Wait you really think that a sound system will slow down your car?? about 0.001 sec?
As I said they don't give any speed upgrade but neither filter gives any speed bump.
miiser is offline   Reply With Quote
Old 04-30-2017, 07:32 PM   #23
Won't happen
Old 05-05-2017, 08:59 PM   #24
SirDigby
sorry. when i think "sound system" i think lots of heavy gauge wire, amplifiers, subs, etc. i forgot we were talking $300...
Old 06-15-2017, 05:34 PM   #25
NJP440
2010EGGHATCH
NJP440's Avatar
Drives: White 2010 Yaris Hatch
Ok time for me to jack this thread. I ordered an intake for my 2010 yaris 3dr and the air sensor does not bolt up at all! Very far off on the bolt holes. Yes I bought a cheap intake but for those who are on the facebook page and remember Aimee and her 3rd gen "laboon" she had the same problem with her AFE intake. Now we are talking $50 intake vs a $300 intake so I can't call quality here, there must be something else at play. Anyone run into this issue? Does our car have 2 different model air sensors?
Pic of my cheap intake for hilarity purposes
Sent from my LG-H918 using Tapatalk
IG: 2010EGGHATCH
NJP440 is offline   Reply With Quote
Old 06-15-2017, 06:14 PM   #26
ecampos
ecampos's Avatar
Drives: 2017 Toyota Yaris S XP-150
I ran into the same issue and had to do this:
Basically modify the stock depurator cap, cut the intake, fit it with couplings. No issues so far.
2017 Toyota Yaris S XP-150: K&N Cold Air Intake, Megan Racing MO-E Muffler, DNA Motoring Exhaust Headers, Pedal Commader throttle controller, NST Pulley Kit, STR 526 17x8.25 rims (Volk TE37 Replica).
ecampos is offline   Reply With Quote
Old 06-15-2017, 06:15 PM   #27
NJP440
2010EGGHATCH
NJP440's Avatar
I'm trying so hard not to cut up my stock parts 😭
IG: 2010EGGHATCH
Old 06-15-2017, 06:19 PM   #28
ecampos
ecampos's Avatar
Oh I didn't... I put away the stock piece and ordered a new one to experiment, it was like $30 xD
Old 06-15-2017, 06:21 PM   #29
NJP440
2010EGGHATCH
NJP440's Avatar
Ohhh ok ill take a look on eBay see if anything pops up
IG: 2010EGGHATCH
Old 06-15-2017, 06:33 PM   #30
ecampos
ecampos's Avatar
So the part number for your car I think is: 17705-21100 CAP SUB-ASSY, AIR CLEANER
Found this on eBay: http://www.ebay.com/itm/2006-11-TOYO...1RP7ry&vxp=mtr
Old 06-15-2017, 06:36 PM   #31
NJP440
2010EGGHATCH
NJP440's Avatar
Oh boy I'm def not a fan of trying to make that work 😂 ill be searching other options
IG: 2010EGGHATCH
Old 06-15-2017, 10:20 PM   #32
SirDigby
your options are; cut up stock box and aftermarket tubing and use 3 couplers and filter. buy another intake. use aftermarket tubing with stock air box. use stock tubing and stock air box.
Old 06-15-2017, 10:21 PM   #33
NJP440
2010EGGHATCH
NJP440's Avatar
So no matter what you're 50/50 odds with ordering an intake?
IG: 2010EGGHATCH
Old 06-16-2017, 12:13 AM   #34
alias06
Drives: 2008 Red Toyota Yaris
Originally Posted by vitz rs gs View Post
I don't have a dyno test but I have tested on the same road my accelaration from 0 to 100 km/h. Before 12 sec after its aprox 10 sec
Stock 0-60 time is in the 10 sec range. I seriously doubt that an intake did anything.
alias06 is offline   Reply With Quote
Old 06-16-2017, 07:29 AM   #35
DiCaprio
Just a Gaijin
DiCaprio's Avatar
Drives: 2006 Yaris 4 door 1.3l
It all comes down to the launch and conditions.
I've done a before and after test with new tires, lightweight alloys and air intake.
The car was stock before.
Before with winter tires and stock air intake the best i could do was 11.1 sec
After with new sticky summer tires and aftermarket air intake the best i could do was 11.3 sec.
So after i did the mods my 0-62 times were worse than before.
So i guess my winter tires stick well enough to put the power down and it all comes down to the launch and your shifting.
You can scrape off some time with good shifting.
But with a bad launch my times are always in the 12-13 sec range.
My engine is the 1.3l 2SZ-FE
DiCaprio is offline   Reply With Quote
Old 06-16-2017, 09:14 AM   #36
I know it seems simple to me, but are you sure you were mounting the MAF in the correct direction. It only goes in one way because the holes are offset.
Simota CF650-6 Air Intake Review invader166 Performance Modifications 16 12-21-2015 03:31 PM
For Sale: Fujita F5 Cold Air Intake invader166 Items for Sale by private party 2 11-21-2015 11:10 AM
tooter's manifold adventure... tooter Performance Modifications 1465 07-31-2014 08:11 PM
AEM cold air intake vs Afe intake... djgab101 Performance Modifications 69 04-28-2013 02:03 PM
cold air intake 400 dollar yaris Performance Modifications 10 10-02-2012 06:33 PM
