Old 05-02-2018, 06:02 AM   #19
sceh
Drives: yaris 2004
yes
sceh is offline   Reply With Quote
Old 05-02-2018, 07:38 AM   #20
dogsridewith
Drives: 2007 2-door hatchback
2007 Generation 2 Toyota Yaris serpentine alternator belt tension squeal replacement
07 Yaris w/ AC serpentine belt. Examine the back of the belt w/ a strong flashlight. Particularly where it runs around the pulley that runs on the front of the belt. I'd clean up a new pulley w/ windex or something but never spray anything on the belt. Tighten if anything more than a chirp on the occasional cold start. Don't overtighten. Beware touching chain tensioner gizmo w/ prybar! Just replace the belt and then you have a spare...sorta inconvenient to be stuck along the road somewhere w/ you or no one able to just throw on a belt and get you going.
(2007 Generation 2 Toyota Yaris serpentine alternator belt tension squeal replacement)
alternator, belt, worn
Should I Change My Oil After 1300 Miles? bronsin DIY / Maintenance / Service 3 10-28-2016 01:25 AM
Oil filter seeping oil from seal : Should I change it ? Hershey DIY / Maintenance / Service 33 11-14-2012 04:25 PM
Oil Change Question... jayeh DIY / Maintenance / Service 4 03-05-2012 11:15 PM
Help with oil change trevor1980 DIY / Maintenance / Service 3 02-05-2012 10:46 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
