Old 03-12-2021, 07:38 PM   #19
Neinris
Went to a pick and pull today, and found a 2007 Yaris Sedan. I pulled the evap canister and pump, but I still have the P043E & F faults. Not sure if the canister and pump I got are also faulty. I can’t put my old one, cause the mounting bolts broke in the housing. Sigh... there’s a 30 day warrantee for the canister and pump that I pulled, I might go back and exchange it for another that’s newer model. The other faults I think is an electrical issue. I wonder where their common points are? I think I’m giving up and gonna ask a pro for help.
Old 03-13-2021, 02:37 PM   #20
remcafee
sounds like a big mess, if you have skills to drill, you need to drill out the broken bolts and get the correct tap to clean the threads, i belive theyre 6x1.00, use a little anti seize when putting new bolts in, you also need to get a shop or the dealer to smoke test it for evap leaks, thats the easiest thing to do and go from there
Old 03-14-2021, 03:13 AM   #21
Neinris
I tried drilling the ones on the side with the pump, but I couldn’t get it centered cause the pump’s in the way. I didn’t want to unbolt the pump, I have a feeling they’d break too. I’ll just leave it alone.
I wouldn’t have removed the brackets from the one I pulled from the junkyard if they didn’t charge for the brackets as well. I already bought new bolts for the canister that I got from the junkyard and yes, I put anti seize, I pretty much put it on almost everything. I’ll learn to keep the bolts from the junkyard next time. One of the weld nut, that secures the canister underneath, also broke off from inside the spare tire compartment. Sigh... Luckily it’s one of the two on the driver side. I bought a replacement nut and bolt, but didn’t bother putting it in yet, as I’ll be returning the canister for a replacement. I’m going to another LKQ, 45 min away, hopefully they have a better inventory. I called in and made sure I can return the part even if it’s from another one of their site. Hopefully I find a Corolla or Matrix with rear disc brakes while I’m there. And of course an evap canister and pump that’s in better shape.
What did you mean by smoke test? The whole car’s evap system or just the canister I pulled?
Old 03-14-2021, 03:43 AM   #22
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Have you put a voltmeter on your alternator? With all those codes, I'm wondering if you're having voltage delivery problems. Of course, you're not having drivability problems, so maybe not.
Old 03-14-2021, 10:32 PM   #23
remcafee
a smoke test will determine and pin point any evap sustem leaks, what you do is pinch off your rear vent by the gas tank and put the smoke tester straight into the evap system and you will see if theres smoke coming somewhere, is your car rusty? sounds like you have a lot of rust with all the bolts that are breaking. i would give your car a wd 40 bath before touching another fastener on that thing
Old 03-14-2021, 11:01 PM   #24
Neinris
Actually, I didn't... That's why I thought maybe my belt was slipping a bit. It passed the voltage test when I used the ODBII reader. I'll check right now.
Old 03-14-2021, 11:06 PM   #25
Neinris
The undercarriage is surprisingly not that rusty, but yes there are components that are, like the bolts that connected the midpipe to the header and axleback, and the bolts that held the evap canister.
I'll test my alternator first, like Adam said, if that's fine then I think I'm done messing with her and just head to the shop. Could it still be possible that my evap is fine and it's just faulting out because of electrical issues?
Old 03-14-2021, 11:23 PM   #26
Neinris
Ok, so I let her warm up to idle, took the negative cable off the battery, and read the alternator to ground, and she's making +14VDC. So that's not it...
Old 03-15-2021, 05:32 PM   #27
remcafee
off to the shops then...
Old 03-16-2021, 08:56 PM   #28
Neinris
YUP! I grabbed a 2012 Corolla evap canister, the related faults didn't go way. So I'm done trouble shooting. I'll post once the shop finds the fix. Stay tuned!
Old 03-12-2022, 08:00 PM   #29
Neinris
Fixed!!!
My apologies it took me forever to reply back. First thing's first, the ODB2 reader that my cousin had, which what I was using when I was back in San Diego was faulty. I ended up troubleshooting the false fault that it was showing, which lead to replacement of parts that didn't needed to be replaced and ended up causing an actual fault. When I got to Maryland, I used my friend's tablet type ODB2 reader and showed the actual fault.
Anyway, I actually fixed this issue a long time ago, back in August when I finally moved back to Maryland. It was the vapor purge solenoid under the hood that was causing the problem. I didn't think it was bad, because I already replaced it when I was chasing the problem. But apparently the one I bought from Auto Zone was intermittently bad, which I paid full price for, I don't even know how much it was, I think around $70. I bought one from eBay for $12 and voila!!! And no CEL ever since.
OFFICIAL Yaris SEDAN thread SimmZ Photo-Video-Media Gallery 1706 06-22-2025 05:33 AM
P0607 and p0138 cel codes coolguyndc Third Gen Yaris General Discussion 17 08-06-2019 01:52 PM
Found this 2014 Mitsubishi Mirage ES yesterday Hershey Off-topic / Other Cars / Everything else Discussions 97 01-30-2014 11:30 AM
Orlando 2/16 Meet 1.5 Southeast 44 03-28-2013 06:50 AM
Fault Codes P0441, 442, 446 soloecho2 DIY / Maintenance / Service 1 04-25-2010 06:21 PM
