Old 06-20-2007, 09:03 AM   #19
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
10 mm, but that was with me and my dad in the front and neither one of us are small guys. I am an ex kickboxer(if your wondering about the weight) 6'4" 300 lbs and my dad is about 230 lbs, and it just barely catches the inner fender in the rear. I didnt have any problems with the front.
Old 06-20-2007, 09:14 AM   #20
Black Yaris
der Zeck
Black Yaris's Avatar
It is also the offset you are running... a few of us running 17's with +42 offsets have come to the conclusion with a lowered suspension on a daily driver, who wants to hit the track every now and then... may want to run a staggared setup to avoid rubbing problems and to get the best preformance out of the wheel/tire combo
205/40R17 +42 on the front
215/40R17 +42 on the rear
This set up may evolve overtime, as for no one that I know is currently running it, it is just a theory at this time.... but I am pretty sure that is the setup going on Chino's car here quick like
Old 06-24-2007, 11:12 AM   #21
OgDogg
Gas Guzzler
OgDogg's Avatar
Drives: 07 Yaris Sedan S
Has anyone tried altering the rear fenders to avoid rubbing?
OgDogg is offline   Reply With Quote
Old 06-24-2007, 12:02 PM   #22
slvryaris
slvryaris's Avatar
Looked into rolling the fenders. You paylike $250 and they send the device in the mail. You roll the fenders and send it back and I think they keep$50 of it and credit the rest back. some people do it old school........heat gun and a baseball bat
Old 06-24-2007, 11:59 PM   #23
OgDogg
Gas Guzzler
OgDogg's Avatar
I was thinking more along the lines of shaving the edge off the inside of the fender. Do you think that would allow enough clearance for the tire not to rub?
Old 06-25-2007, 12:26 AM   #24
slvryaris
slvryaris's Avatar
Possibly but I am not for sure about shaving it. I dont do alot of body work, but someone on here can point ya the right way. I would roll mine that way there is not a sharp edge that MIGHT catch and then pop your tire.
Old 06-25-2007, 12:56 AM   #25
mojoyaris
Ecurie Snoopy Lives
mojoyaris's Avatar
Drives: Jojo
I'm taking out those plastic liners after the megans go in
Sponsors and Organizations:
Toyota Rally Canada
Yokohama Tire Canada
Western Canada Rally Association
Ecurie (Team) Snoopy Canada, racing since 1966
mojoyaris is offline   Reply With Quote
Old 06-25-2007, 01:54 AM   #26
Vanderkitten
Vanderkitten's Avatar
Drives: 2007 Yaris Hatchback
Originally Posted by largeorangefont View Post
Get some camber bolts. I have the same issue and my camber is off. Gaining some more negative camber will help fix the problem and even out tire wear
Where did you get yours? Is that cobra a Mustang or a Superformance?
Dave V- Creator-Vanderkitten- Clothing for Women Who Kick Ass!
Many thanks to our sponsors:
Weapon-R http://weapon-r.com
Megan Racing http://www.meganracing.com
Les Schwab Tires http://www.lesschwab.com
317 graphics http://www.317graphics.com
Vanderkitten is offline   Reply With Quote
Old 06-25-2007, 01:56 AM   #27
Vanderkitten
Mine just started rubbing, alignment was just done not long before, I lowered the car a little for the track. There is a hole rubbed in the plastic. I thought about taking my heat gun and melting/bending the plastic in. I have 205/45/17's with MR Coilovers.
Old 06-25-2007, 02:59 PM   #28
OgDogg
Gas Guzzler
OgDogg's Avatar
It seems like that would only add a few mm's of clearance. Do you think that would be enough to make a difference? How do you go about removing them? Is there an easy way or is it just however you can manage? Any DIY's available on this?
Old 06-25-2007, 03:12 PM   #29
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
no lining = filthy as a pig engine bay, might even get soem critters living in there
SPONSORED BY
Old 06-25-2007, 03:13 PM   #30
nqd
Drives: 07 Yaris LB Absolute RED
If you remove the plastics, doesnt water get near the engine?
nqd is offline   Reply With Quote
Old 06-25-2007, 03:32 PM   #31
brickhardmeat
Lonesome Cowboy
and cats
SPONSORED BY
Old 06-25-2007, 04:53 PM   #32
OgDogg
Gas Guzzler
OgDogg's Avatar
MMM... Cat Engine stew.
Old 06-25-2007, 09:26 PM   #33
slvryaris
slvryaris's Avatar
We need to find some one who does aluminum work and shape new fenders and raise the wheel well height like we did with body dropped trucks.
Old 06-25-2007, 09:45 PM   #34
brickhardmeat
Lonesome Cowboy
we could always rip the front fenders off and rat rod the shit out of 'em
seriously if someone put the time and effort into it, this could be one mean looking moderen rat rod
gotta use your imagination big time
SPONSORED BY
Old 06-26-2007, 12:25 AM   #35
slvryaris
slvryaris's Avatar
Hmmmm...... I have seen a radio flyer chopped in half and used as wheel wells before.
Old 07-03-2007, 03:50 PM   #36
njyaris
YARIS NEWBIE
njyaris's Avatar
Drives: YARIS 07 LIFTBACK
Send a message via AIM to njyaris Send a message via Yahoo to njyaris
i just installed Tien s Tech springs approx 2" drop all around
i also installed 18" Rims w/ Falken 215/18/35's
42 offset ( i wished i would have gotten 17"'s instead less offset and 40 series tires.. that's for you newbies..
.. im rubbing ..
now - the guy who took the time to post the pic showing the area that rubs - yup thats exaclty right .. (me too)
i plan on rolling the fenders .. i'll try to find somewhere online where i can rent a fender roller .. not sure if i can - if anyone knows of a place let me know!
otherwise I will do this ole skewl style .. baseball bat (wooden)
my tires are fine but i just installed the springs a few days ago .. i suspect that the springs will settle therefore dropping my car even more, hence more rubbing - real bad
so i'm most likely going to wallmart tonight . will get a ten dollar wooden baseball bat .. jack up my car and place the baseball bat in between the fender and the tire (tight fit) then roll roll roll away .. hope i dont crack the paint .. but if i do i already decided i can live with it .. touch up paint my friendz
any thoughts !!!?>>
Hudson County, New Jersey
njyaris is offline   Reply With Quote
new rims, some rubbing, best fix? cali yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 06-04-2007 05:26 PM
Checkout the drop! spkrman Wheels, Tires and Suspension Forum sponsored by The Tire Rack 25 05-06-2007 12:06 PM
need 17inch rim guidence chino_potato Wheels, Tires and Suspension Forum sponsored by The Tire Rack 46 04-09-2007 12:09 PM
